DSW Allez Gallery.. show us your smartwelds
CrankAddictsRich
by CrankAddictsRich
jamin wrote:
CrankAddictsRich wrote:Been doing some work on my Allez...
stripping the paint.
and then brushed finish w/ black S-Works Tarmac fork. 150g worth of weight loss between the frame and fork. Some of that will go back on when I put some vinyl graphics on and clear coat it.
Looking forward to seeing this finished - I've been thinking about doing this to my DSW - what did you use to strip the frame?
I used a product called "aircraft stripper." It is wicked stuff and makes short work of the paint. It is a form of jelly, so it's a little messy and cumbersome to work with, but it works well.
https://www.amazon.com/GAR343-KLEAN-STRIP-Aircraft-Stripper-Gallon/dp/B004Y1KX9E
jamin
by jamin
CrankAddictsRich wrote:I used a product called "aircraft stripper." It is wicked stuff and makes short work of the paint. It is a form of jelly, so it's a little messy and cumbersome to work with, but it works well.
Thanks, it looks quite effective! Good luck with the build!
by Nefarious86
Part one of the monster green snot project.
Using Tapatalk
burglarboycie
by burglarboycie
That's looking good!!
jamin
by jamin
WOW!!!!!!
Not sure about the S-Works decals though, although I think the S-Works frame was pretty much the same just anodised silver, so I guess its cool.
CrankAddictsRich
by CrankAddictsRich
jamin wrote:WOW!!!!!!
Exactly.
SpecializedColnago
by SpecializedColnago
Came in at 6.88kg as you see it. Unfortunately it will be swapped to the white and chrome model in about a month as the paint is having cracking issues on the non drive side chain stay and will be warranty replaced. The thing is a beast to ride and surpassed all of my expectations with power transfer while still maintaining comfort.
jamin
by jamin
Exactly.
Cant wait to see it built!
jamin
by jamin
Stunning!!!! That DA crank works so well too!! Nice one!
CrankAddictsRich
by CrankAddictsRich
jamin wrote:Stunning!!!! That DA crank works so well too!! Nice one!
Yes, it needed to have a DA crank. I had Ultegra on the bike previously, but I knew the DA crank had to happen. It helped that I wanted to switch my Venge up to 52-36, so I bought a new crank for that bike and took this 50-34 off the Venge.
SpecializedColnago
That came out awesome! After seeing this thing finished you have helped me make up mind with what finish I want on my caad 9 frame.
upside
by upside
TERRIFIC job and it does look stunning. Did you end up clear coating the frame.... where did you buy the decals. I may try this as I had a SmartWeld last year and really enjoyed it and now looking for another one
CrankAddictsRich
by CrankAddictsRich
upside wrote:TERRIFIC job and it does look stunning. Did you end up clear coating the frame.... where did you buy the decals. I may try this as I had a SmartWeld last year and really enjoyed it and now looking for another one
Yes.. I did clear-coat the frame. I got the decals from the internet.
