New guy... these are my rides.
CrankAddictsRich
by CrankAddictsRich
The cables are perfect... just enough to clear as bars turn side to side.
As for smiling on the start line... oh well.
jbaillie
by jbaillie
Rich I was looking at your blog - I didn't see anything on the re-finishing of the Allez. Any chance you've done a write-up on that? Very curious about the process.
CrankAddictsRich
by CrankAddictsRich
jbaillie wrote:
Thu Sep 13, 2018 4:42 pm
Unfortunately, I dind't shoot the whole process... I should have, I know. Truthfully, there wasn't much to it... I used a product called aluminum aircraft stripper. You can find it at most autoparts stores. It is like a jelly that you put on the frame and it basically just eats the paint. It literally lifts the paint right off the metal frame. The main tubes came clean pretty quickly, but inside the rear triangle, dropouts, behind the seat tube etc, I had to do multiple coatings of the material. I'm guessing because of overspray from multiple coats in these areas when the bike was being painted. When it was all stripped, I took several days of working the material with some steel wool. I wanted a brushed look and not a highly polished, chrome look, so I just took my time getting the right amount of brushin on the finish. At that point, I cut the vinyl decals, appled them and then had a friend that owns a body shop, spray it with clear coat. As for the fork, I ordered an all-black, S-Works Tarmac fork from my LBS.
jbaillie
by jbaillie
Extremely helpful, thanks! And when dealing with the aircraft stripper you just used regular rubber gloves? Guessing that stuff is pretty nasty on the skin.
CrankAddictsRich
by CrankAddictsRich
Yes... some heavy duty rubber gloves, but I didn't touch it with my hands at all. I did get iy on my skin in a spot of two and it did sting. I washed it off immediately. More than that though, is the smell... defintiely do it outside, in a ventilated area.
CrankAddictsRich
by CrankAddictsRich
I haven't updated this thead in a while, but I've been on a steady prescription of racing... TT's and dabbling in crits to finally get some upgrades.
rollinslow
by rollinslow
All your bikes are great but that S-works Allez is incredible. I wish I had picked one up when I had the chance. Such a unique frame.
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12 (viewtopic.php?f=10&t=161577)
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-GRX Di2
CrankAddictsRich
by CrankAddictsRich
rollinslow wrote:
Fri May 31, 2019 7:53 pm
To be fair... it is not a legitimate S-Works Allez as sold by Specialized. It started life as an Allez Comp DSW which has the same frame as the S-Works but came with a standard Tarmac fork as opposed to the S-Works Fork. The S-Works Allez had no paint just anodized graphics to preserve the lightest weight possible. I stripped the paint from my Allez Comp and then gave it a brushed finish and had it clear-coated. I bought an all black S-Works Tarmac fork from my LBS and between the frame and fork, dropped it roughly 200 grams. The legitimate S-Works Allez bikes are definitely pretty rare ad great bikes. I love my riding my Allez and even though it is the "lesser" of my road bikes I still ride it a lot. It is my trainer bike and also my road race/crit bike, so I don't have to worry about binning my S-Works Tarmac SL5. I usually use the Allez in winter too, although I just picked up a new project that will become the winter/gravel bike....
It is a limited edition copper E5 Aluminum Diverge
COSTA
by COSTA
very nice bits of kit in here, photos are super clear too.
Bliquid
by Bliquid
Rich, on your 2015 Venge, what saddle height did you run? Just came across an older post of yours on sizing of the older Venge. Am about the same height as you and debating 52 vs. 54.
Thanks,
Ben
CrankAddictsRich
by CrankAddictsRich
Bliquid wrote:
Mon Jul 15, 2019 11:28 am
Thanks,
Ben
I don't have the Venge anymore so I can't give you an exact measurement on that bike... but both my Tarmac and Allez are set up with the same fit and the measurment is 70cm from the center of bottom bracket to the top of the saddle, measuring straight along the seat post angle. In terms of sizing, my Tarmac now is a 52, and my Allez is a 54 like the Venge was. I've got the fits set up exactly the same between the two bikes... the only difference is that the Tarmac has 10mm of spacers under the stem, so if I want to go lower on the front of that bike I can. On the Allez, I could go lower only if I resorted to one of those really thin slam your stem bearing covers.
CrankAddictsRich
by CrankAddictsRich
I finally got the Diverge E5 put together... pretty basic build. I didn't weigh it, because I'm fairly certain it isn't that light, although it does feel lighter then I expected.
2018 Specialized Diverge E5 limited edition Copper frame set.
spdntrxi
by spdntrxi
I like it looks like the "aero" setup.... lets see the 650b shoes.
Love the frame colorway
CrankAddictsRich
by CrankAddictsRich
spdntrxi wrote:
Thu Sep 05, 2019 6:43 pm
I should have them ready to go on this weekend.
