2017 Specialized S-Works Tarmac SL5, 14.8 lbs/6.7 kg
Frame: 2017 Specialized S-Works Tarmac SL5, size 52
Fork/Headset: Specialized Fact Carbon with CeramicSpeed headset bearings
Crankset/Bottom Bracket: Shimano DA9000 52-36 w/ Stages DA9000 pm / CeramicSpeed bottom bracket
Pedals: Shimano DA9000
Drivetrain/Cog/Chainring/Chain: Shimano DA9000 52-36, KMC X11SL / Shimano Ultegra 6800 11-28
Derailleurs/Shifters: Shimano DA9000
Handlebars/Stem: Specialized S-Works Aerofly/ Fizik Cyrano R1 100mm, 7*
Saddle/Seatpost: Fizik Antares 00 carbon/ Fizik Cyrano 00 carbon
Brakes: ee brakes
Front Wheel/Hub/Tire:
Yoeleo SAT Superlight 60mmx25mm/ Yoeleo SL-Pro ceramic hub/ 25c Vittoria Corsa G+
Rear Wheel/Hub/Tire:
Accessories: Taxc Tao Carbon cages/ Fizik Superlight Soft Touch bar tape/ Revolutionaries 3Dprinted Fizik direct mount
2015 Specialized Allez Comp, 16.7 lbs/7.57 kg
Frame: 2015 Specialized Allez Comp size 54
Crankset/Bottom Bracket: Shimano Ultegra 6800 52-36 w/ Stages 6800 pm / Praxis OSBB conversion
Drivetrain/Cog/Chainring/Chain: Shimano Ultegra 6800 52-36, KMC X11SL / Shimano DA9000 11-28
Derailleurs/Shifters: Shimano 105 5800
Saddle/Seatpost: Fizik Antares R1 carbon/ Fizik Cyrano R1 carbon
Brakes: Shimano Ultegra 6800
Yoeleo SAT Superlight 50mmx25mm/ Yoeleo SL-Pro ceramic hub/ 24c Specialized S-Works Turbo
Yoeleo SAT Superlight 50mmx25mm/ Yoeleo SL-Pro ceramic hub/ 26c Specialized S-Works Turbo
Accessories: Taxc Tao cages/ Specialized Roubaix tape/ Barfly Fizik mount
2015 Specialized S-Works Allez, 15.2 lbs/6.89 kg
Frame: 2015 Specialized Allez stripped to bare metal and clear-coated, size 54
Fork/Headset: Specialized S-Works Tarmac 11R
Crankset/Bottom Bracket: Shimano Dura-ace 9000 50-34 w/ Stages DA9000 pm / Praxis OSBB conversion
Drivetrain/Cog/Chainring/Chain: Shimano Dura-ace 50-34, KMC X11SL / Shimano Ultegra 6800 11-28
Derailleurs/Shifters: Shimano Dura-ace 9000
Brakes: Shimano Dura-ace 9000
Accessories: Taxc Tao cages/ Fizik soft touch tape/ Barfly Fizik mount
2015 Specialized Venge Pro, 15.7 lbs/7.12 kg
Frame: 2015 Specialized Venge Pro size 54
Crankset/Bottom Bracket: Shimano Dura-ace 50-34 w/ Stages DA9000 pm / Praxis OSBB ceramic bb conversion
Drivetrain/Cog/Chainring/Chain: Shimano Dura-ace 9000 50-34, KMC X11SL / Shimano Ultegra 6800 11-28
Saddle/Seatpost: Fizik Antares 00 carbon/ Specialized Venge aero seat post
Brakes: ee brakes
Yoeleo SAT Superlight 60mmx25mm/ Yoeleo SL-Pro ceramic hub/ Vittoria Corsa G+ 25c
Accessories: Taxc Tao carbon cages/ Specialized Roubaix tape/ Barfly Fizik mount
2014 Specialized S-Works Shiv TT Lululemon team bike (more pics on page 6+7)
Frame: 2014 Specialized S-Works Shiv TT Lululemon Team bike size 54
Fork/Headset: Specialized S-Works Fact Carbon
Crankset/Bottom Bracket: Shimano Dura-ace 53-39 w/ Stages DA9000 pm / Praxis OSBB ceramic bb conversion
Drivetrain/Cog/Chainring/Chain: Shimano Dura-ace 9000 53-39/ KMC X11 DLC / Shimano Ultegra 6800 11-23
Derailleurs/Shifters: Shimano Ultegra 6870 TT Di2
Handlebars/Stem: Specialized S-Works TT w/ Specialized S-Works ski-bar extensions/ customized S-Works Shiv TT stem
Saddle/Seatpost: Specialized S-Works Power saddle/ Specialized Shiv TT aero seat post/ Revolutionary 3D printed Di2 mount
Brakes: Shimano Ultegra 6870 Di2 brake levers, TriRig Aero front brake, Specialized S-Works Shiv TT bottom bracket brake
Yoeleo SAT Superlight 88mmx25mm/ Yoeleo SL-Pro ceramic hub/ Vittoria CorsaSpeed G+ 23C
Yoeleo SAT full carbon disc/ Yoeleo SL-Pro ceramic hub/ Vittoria CorsaSpeed G+ 23C
Accessories: Barfly TT mount / Fizik Superlight soft tape / CeramicSpeed OSPS
2016 Specialized Fuse Comp (more pics on page 7)
Frame: 2016 Specialized Fuse Comp size 17/M
Fork/Headset: Rockshox Pike RCT3 SoloAir 120mm travel
Crankset/Bottom Bracket: Shimano XT M8000 30 tooth / Praxis OSBB conversion
Pedals: Crank Brothers Stamp
Drivetrain/Cog/Chainring/Chain: Shimano XT M8000 30 tooth/ Shimano 11 speed chain / Shimano XT M8000 11-42
Derailleurs/Shifters: Shimano XT M8000
Handlebars/Stem: RaceFace Next carbon 1/4" rise 720mm/ RaceFace Atlas stem 50mm
Saddle/Seatpost: Specialized Henge Comp/ TranzX dropper 100mm travel
Brakes: Shimano XT M8000 180/160
WTB Scraper i45/ Specialized Stout XC hub/ Specialized Purgatory 27.5x3.0
WTB Scraper i45/ Specialized Stout XC hub/ Specialized Ground Control 27.5x3.0
Accessories: Wahoo Elemnt Bolt mount/ Ergon grips /
2018 Specialized Diverge E5 limited edition copper frame set, approx. 17.5 pounds... more pics on page 8
Frame: 2018 Specialized Diverge E5 limited edition copper frame set, size 54
Fork/Headset: Specialized Diverge carbon fork/ Future shock headset
Crankset/Bottom Bracket: Shimano 105 R7000 50-34 w/ Stages 5800 pm / Shimano DA9000 threaded BB
Pedals: Shimano XT SPD
Drivetrain/Cog/Chainring/Chain: Shimano 105 R7000 50-34, KMC X11 / Shimano Ultegra R8000 11-32
Derailleurs/Shifters: Shimano Ultegra R8000
Handlebars/Stem: Specialized S-Works shallow drop/ Fizik Cyrano R1 110mm, -21*
Saddle/Seatpost: Fizik Antares R1 carbon/ S-Works CG-R carbon seat post
Brakes: TRP Spyre SLC flat mount
Yoeleo SAT Superlight 50mmx25mm/ DT Swiss DT240 straight pull hub/ 38c Specialized Pathfinder Pro
Accessories: Specialized Rib cage/ Specialized S-Works Roubaix tape/ Wahoo Elemnt Bolt mount
