Giant OverDrive vs. OverDrive 2 fork/head tube sizing for RO
Hello all,
I'm contemplating a fork change for my Giant Propel Advanced, which has an OverDrive fork.
The rep at Giant says that an OD2 fork won't fit, because the headtubes are different between Advanced and Advanced Pro/SL models. Is that really the case? Can I fit a OD2 fork into my bike with a different headset?
SHUT UP LEGS
2015 Giant Propel Advanced
2015 Cannondale Supersix Evo
2013 KTM Strada mod. (totaled)
2011 Pinarello Dogma 60.1(loaner)
2011 Scott SUB 45(sold)
Politecnico di Milano Ingegneria Meccanica
OD is 1-1/8" top 1-1/4" bottom. OD2 and 1-1/4" top 1-1/2" bottom.
http://www.giant-bicycles.com/en-us/tec ... rdrive/50/
So, will it fit?
SHUT UP LEGS
On this topic, does anyone know where I can get an aftermarket 'overdrive' headset bottom bearing?
Local shops says that OEM ones aren't available (UK) and I have to buy a new headset full at £35. Which seems a little steep to me.
I've looked online but I can't ssem to find one with the little 45degree schamfer.
- jekyll man
Official cafe stop tester
I have removed the fork and took some measurements of the bearing seats.
Upper bearing seat OD: 42 mm, ID: 36,3 mm
Lower bearing seat OD: 46.9 mm, ID: 43 mm. The measurement that I find to be the most critical, which is the upper seat ID and the smallest diameter in the head tube, is larger than 1 1/4", tells me that an OverDrive 2 fork will at least go through.
The OD measurements also match the bearing sizes listed in the link jekyll man posted, reinforcing my guess that Propel Adv/Adv Pro have the same head tube dimensions.
The plot thickens...
Sent from my calculator using Tapatalk
SHUT UP LEGS
I swear I read something on another website about the forks being interchangeable, provided you use the correct headset.
If the OD measurements match on the Adv and Adv/Pro I'd be inclined to believe if you got the Adv/Pro headset and fork they will fit on your Adv. frame.
I write the weightweenies blog, hope you like it
Disclosure: I'm sponsored by Velocite, but I do give my honest opinion about them (I'm endorsed to race their bikes, not say nice things about them)
- Similar Topics
- Replies
- Views
- Last post
- 1 Replies
- 191 Views
Last post by BdaGhisallo
Sun Nov 04, 2018 9:08 pm
- 16 Replies
- 1392 Views
Last post by mattr
Sat Nov 03, 2018 6:45 pm
- 4 Replies
- 375 Views
Last post by Bigger Gear
Mon Apr 09, 2018 1:40 am
Giant/Liv carbon steerer marks (Giant owners please chime in)
by sparklywheels » Sat Dec 08, 2018 11:24 pm » in Road - 4 Replies
- 330 Views
Last post by beanbiken
Sun Dec 09, 2018 5:35 am
- 6 Replies
- 450 Views
Last post by outnumbered
Tue Jul 17, 2018 12:17 pm
