Show us your sub-6kg builds
RyanH
by RyanH
I figured a thread to aggregate the sub-6kg builds would be nice. Probably should be a thread for sub-5kg since those are true WW builds while the sub-6kg crowd is more or less just crossing the lines of a WW build (in my opinion).
I'll go first:
A Ti Reunion: My WW Litespeed Xicon - 5.76kg (HiRes Pics Up)
My attempt at a WW Colnago C59 @ 5.70kg
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
AZR3
by AZR3
Hoping to get my R3 under 6k, I'm right on the edge at 6290 but soon I should be dropping some grams!
And that's with Power2Max Type S power meter and BBInfinte bottom bracket, so those two things right there added 166g over the stock spider and bottom bracket
RyanH
by RyanH
Pssh...I've done both of mine with a powermeter and heavy frames, one of which is 1300g!
Strava
AZR3
by AZR3
Well I don't run tubs so that's a couple hundred grams right here as well. Also not running any exotic parts, zipp bars, rotor crank and 1350g Alu clinchers.
kevosinn
by kevosinn
Here is a few for you.
my 4.64 kg Scott addict. (paint stripped to save weight)
And my latest Cryptic frame. 5.6 kg with a full di2 group.
kakan
by kakan
That last Cryptic was wonderful!
Marin
by Marin
My FM066 @ 5.98kg:
Switching from Contis to SWorks got me back above 6000g though, currently it's sitting @ 6.09kg and looks like this:
I have absolutely no idea where I could save some 100g without spending a fortune or losing functionality... :(
I want aero bars & wheels, fast clinchers, oval chainrings, 11-28 cassette, padded saddle, steel pedal spindles, normal cable housing. Suggestions?
akaricerocket
by akaricerocket
my Cervelo 5.68kg 12.5lbs
and trek District 5.45kg 12lbs
Vallinotti
by Vallinotti
Here is the mine :D
Frame - AX-Lightness Vial EVO 52cm
Fork - THM Scapula CT
Headset - AX-Lightness stock
Wheels - Meilenstein Obermayer Tubular
Tires - Continental Competition 22mm
Skewers - Lightweight
Crankset - THM Clavicula M3 110mm / SRM
Chain - KMC X11SL-DLC-Black
Chainrings - Praxis Works 52/36
Front derailleur - Sram Red 22
Rear derailleur - Sram Red 22
Chain Catcher - Carbonice
Shifters - Sram Red 22
Cassette - Sram Red 22
Brakes - THM Fibula
Stem - AX-Lightness Rigid 120mm
Handlebar - MCFK without stickers
Handlebar plugs - Carbonice
Handlebar tape - Deda Elementi cork
Seatpost - AX-Lightness stock
Seatpost - AX-Lightness Daedalus 27.2x350mm
Saddle - AX-Lightness Leaf
Pedals - Time Xpresso 15
Brake housing system - AICAN Bungarus housing and cables
Shift housing system - Power Cordz Swift Cable System
Bottle cage - Mighty
sugarkane
by sugarkane
My Parlee when it was 5.3kgs
And at 5.7kgs with the race wheels
jsinclair
by jsinclair
I'm pretty sure this was 5.8kg in this photo. Maybe it was with slightly different wheels, i cant quite remember.
sugarkane
by sugarkane
A beautiful machine Jsinclair
BmanX
by BmanX
Some stunning builds. I can't wait for someone to build a frame using SRAM eTap and the frame only has a cable run for the rear brake. This would be exciting for me to see.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT for 2 decades
stevec1975
by stevec1975
5.69 KG Scott CR1:
I am thinking of Sram Red eTap on this, when I can get hold of the parts, at which point I will strip off the paint on the frame, remove cable stops etc.
cerro
by cerro
My old Cannondale Caad10, missed alu in this thread. 5,74kg:
/jonas l
