2016 Fuji SL
Allen254
by Allen254
gavin wrote:A quick question also noticed a lot of these Fuji builds contain carbon wheels
Would you run those in the mountains ?
I always was informed carbon clincher wheels in the mountains fail
I love the way carbon breaks over aluminum, never had problems with carbon braking. Aliluminum breaking for me at least I don't like the way aluminum bites before breaking throwing your handling off a bit while cornering, carbon is smooth breaking sort of like faded breaks from heat but in a good controlled way. And I have always had brake chattering with aluminum breaking surfaces
prendrefeu
by prendrefeu
Brakes.
Not breaks.
Know the difference.
Allen254
by Allen254
prendrefeu wrote:Brakes.
Not breaks.
Tell that too samsung
gavin
by gavin
Not breaks.
Tell that to Samsung :)
mpulsiv
by mpulsiv
Allen254 wrote:I love the way carbon breaks over aluminum, never had problems with carbon braking. Aliluminum breaking for me at least I don't like the way aluminum bites before breaking throwing your handling off a bit while cornering, carbon is smooth breaking sort of like faded breaks from heat but in a good controlled way. And I have always had brake chattering with aluminum breaking surfaces
What brake pads were you using? Switch to Kool-Stop salmon brake pads.
jz4nyc
by jz4nyc
Nice looking build. :thumbup:
justaute wrote:A couple of photos. Finished the build. Even with 28mm tires (Hutchinson Sector), the total weight is still impressive. I will soon go back down to 25mm tires and that should drop another 80-100 grams or so. Also, the skewers are stock Campy. Yes...I mix brands. :)
Weight= 6.76 kg (14.9 pounds)
Allen254
by Allen254
Anyone else with some pics,,, and can anyone comment on the stiffness of the fuji sl??
steventran
by steventran
Is that gap between the fork and the bottom of the headtube supposed to be there?
Allen254
by Allen254
steventran wrote:Is that gap between the fork and the bottom of the headtube supposed to be there?
Probably not it should be flush.
newforker
by newforker
upside down bearing?
justaute
by justaute
The fork situation has been rectified. Should not have used the extra race that came in the box.
prebsy
by prebsy
that's yummy. No clearance issues with the 28s?
justaute
by justaute
prebsy wrote:No clearance issues with the 28s?
Short answer = No.
Long answer = depending on the wheel/tire combination.
I had Sector 28 on my Bora and I had ~3mm of space between the tire and the seat-tube. No issues on the chainstays. As of now, I have Schwalbe Pro One 25mm on the same wheels. Not sure if it could accommodate 28mm version of the Pro One.
Allen254
by Allen254
Short answer = No.
how is the stiffness on your fuji sl I'm planning on getting one soon. And how would you you compare it to other carbon bikes that you have ridden stiffness wise?? Sweet build by the way.
Allen254
by Allen254
Short answer = No.
