Assos apparel questions
Kit Brand Talk. Everything under the sun, including sunnies!
Mr.Gib
by Mr.Gib
GTS, or GTO if you have the money. Both have a version of the C2 pad which is 15mm thick. FWIW I preferred M in the T Cento Evo, but L is a better fit for me in the GTS/GTO.
ratef42
by ratef42
kode54 wrote:
Thu May 25, 2023 10:19 am
harblhat wrote:If the legs are actually so loose that they ride up then that size is definitely too big. The fit difference between Mille and Equipe likely won't take up loose fabric within the same size, it would be more a matter of compression.
The Targa also have better leg grippers if that's a concern.
I wear M in Castelli but S in Assos bibs myself.
Vanity sizing with newer Assos gear. I used to wear M with Assos several years ago. Now, all the newer S fit like my older M and I haven’t lost any weight. Image
This is normal to see coming from older generations yes. The newer textiles used will have a greater 4 way stretch capacity in the broad muscle supporting panels, and crucially a greater return support capacity.
This vastly reduces the amount of material displaced away from the skin and ensures a supportive yet comfortable wrap effect from the hips, all the way down to leg gripper.
MrRolandos
by MrRolandos
Today I tried GTO, GTS and RSR S9. RSR S9 is perfect for what I searched for, nice and tight and good compression. Compared to my GTS and S9 alot of difference.
Too bad the jerseys are still a bit loose on the arms but they dont roll up or anything.
ratef42
by ratef42
MrRolandos wrote:
Fri Jun 02, 2023 8:56 pm
You simply need to size down. If jerseys are too loose in the arm, it is categorically too big for you.
iamraymond
by iamraymond
I’m interested in the latest Mille summer jerseys. Does anyone know if they have the same sleeve length as the Équipe RS? I have an older Mille jersey (small) but the sleeves aren’t as long nor are they as tight fitting as the Équipe RS (médium)
MrRolandos
by MrRolandos
ratef42 wrote:
Mon Jun 05, 2023 1:38 am
Nahh I tried size smaller, no way. Its just the design, all bibs are a bit looser, i can pull legs a bit, they stay in place just not very tight. I am 196cm and 86-87kg. Wearing L in both, M no way. It is just the arms I prefer a bit tighter.
ratef42
by ratef42
MrRolandos wrote:
Mon Jun 05, 2023 2:03 pm
As long as it doesn’t create a gap between material and the skin then just go with what’s comfortable. But size does play a role with support of your pockets, correct compression and retaining position of arm warmers, and aiding the transfer of sweat away into gaseous vapor giving a mild cooling effect in high temps.
In short, if you can do the zip up, it’ll fit you on the bike.
g32ecs
by g32ecs
How does the RS S9 Targa compare to the older RS Aero jerseys?
They should fit the same being RS correct?
https://www.assos.com/ca/equipe-rs-jers ... 23-1f.html
https://www.assosoutlet.com/us/equipe-r ... 18218.html
ratef42
by ratef42
iamraymond wrote:
Mon Jun 05, 2023 12:42 pm
Current range is the same length
Nplus1
by Nplus1
g32ecs wrote:
Tue Jun 06, 2023 2:28 pm
My experience is that they are extremely similar, if not identical, in terms of fit (based on size medium in both styles).
g32ecs
by g32ecs
Nplus1 wrote:
Wed Jun 07, 2023 10:45 pm
Thank you, went with my old size
justkeepedaling
by justkeepedaling
Could anyone tell me the difference between the RSR S9 and the RSR S9 Targa bibs? Visibly, the stitching is different on the front, but very similar otherwise, is this a generation thing?
Matte86
by Matte86
I haven’t asked them specifically about the RSR bibs, but about Alleycat, Jodah jacket and arm/leg warmers and they told me targa means a completely new way from the ground up to build/stitch all pieces together paving the way for better and future innovations.. plus they made some small changes which are from customers feedback to improve even more but bottom line is that they are very subtle and not always worthy it
BdaGhisallo
by BdaGhisallo
Are the EQUIPE RS BIB SHORTS WERKSTEAM S9 bibs just cosmetically altered versions of the pre-Targa RS S9 bibs?
I'm not enjoying the Targas (legs too long, mostly) and I'm looking to get a few of the former generation of RS S9 bibs.
kytyree
by kytyree
If you go back to page 134 of this thread I posted a picture of the differences as I saw them. I like the Werksteam version better but they're not radically different, it's been awhile since I used original the RS S9 but if the Werksteam were significantly longer I would notice as I always liked the often shorter assos inseams.
