godzuki26
by godzuki26 on Thu May 07, 2015 8:59 am
I will be using Ultralite Cirrus Ti Pedals.....They are no longer in business so I need to be really careful with my cleats as I will not be able to replace them.
godzuki26 on Tue Aug 29, 2017 2:19 am, edited 3 times in total.
godzuki26
by godzuki26 on Thu May 07, 2015 9:05 am
For my wheelset I will be using some old Lew Pro VT1 wheels that I recently took off my BH Ultralight and replaced with 77 Composites wheels. I will need to use some spacers and will use the Absolute Black 16 tooth cog.
Weight without tires is 892 grams:
Weight with Tufo Elite Jet tires already glued on:
godzuki26 on Tue Aug 29, 2017 2:20 am, edited 1 time in total.
godzuki26
by godzuki26 on Thu May 07, 2015 9:14 am
To keep the weight as low as possible I am going to avoid using STI brake levers and road handle bar. STI levers along with their rubber grips are quite heavy even if paired with Tune\BTP carbon clamps. This will probably look kind of ugly but I am going to use a 100mm Ax Lightness Zeus MTB stem along with a Schmolke TLO 25.4mm MTB straight bar. I will also use the KCNC VB1 brake lever which is only 25 grams. Add some Extralite foam grips and I will have a very light cockpit.
Stem: Ax Lightness Zeus MTB
Bar: Schmolke TLO 25.4mm
Lever: KCNC VB1
Housing: AiCan Bungarus
Cable: KCNC Ti
Grips: Extralite Foam
Expander: Extralite Ultrastar 2
Headset: Extralite Scalhead
Topcap: MCFK
Calipers: Ax Lightness Orion
Saddle: Dash p3 in matte black, black logo, black rails
Seatpost: Tune Cappy seatpost stopper
I will take more pictures and update this thread once I get the frame back from Spyder Composites.
**Special Tip**
Be very careful when using Carbo Lift because it will eat through filler once you get past the primer. When the filler is eaten away beneath the paint/primer, when one tries to clear coat it you no longer have a smooth surface. This in turn will cause pits on the finish if you clear coat the frame. Spyder Composites had to re-apply filler, re-sand the frame, then add clear coat to avoid the pits caused by the uneven surface. If I had to do it again, I would wet sand the final layers of paint/primer rather than going crazy with the Carbo Lift.
godzuki26 on Thu May 07, 2015 9:39 am, edited 1 time in total.
