aquilinx
by aquilinx on Mon Oct 25, 2021 5:52 pm
WheresWaldo wrote: ↑Mon Oct 25, 2021 4:08 pm
@aquilinx
Take a look at this link,
https://a360.co/3Gk1ZbT
It pushes the cateye back 20 mm. But is will be lower than your picture by around 8 mm. I need to do that to make up for anything molded into the shell of the Specialized saddle. Not all of them are completely flat on the bottom. I didn't change the angle from the standard that Speciailized uses on the SWAT taillight.
@aquilinx
thanks it looks great to me
WheresWaldo
aquilinx
WheresWaldo
kode54
by kode54 on Tue Nov 30, 2021 3:26 pm
Hey Bud,
Do you plan to make any Hammerhead Karoo2 mounts that replaces the Garmin adapter interface?
There's the single center screw and the K-Edge 2-bolt mount as well.
Just curious as I prefer the locking mechanism of the K2 v2 than the Garmin adapter interface.
- Factor 02 VAM Disc
- Factor LS Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Moots Vamoots Disc RSL Ti
WheresWaldo
by WheresWaldo on Wed Dec 01, 2021 4:48 am
@kode54
I haven't seen the K2 interface, If you could send me one or point me to where I can get a K2 mount I can make an interface for the K-Edge and Enve mounts.
kode54
by kode54 on Wed Dec 01, 2021 3:50 pm
I have to dig mine out. I put the Garmin adapter in mine...which made the transition easier across all bikes. But that means, there's the Garmin puck, the K2 Garmin adapter, then the Karoo2 GPS computer.
MadCAD makes a few...but not just the puck...which I'm hoping can just sit inside the out front cavity and held by either one center M3 or two side by side M3 bolts.
https://www.shapeways.com/product/J86CU ... 3&li=shops
- Factor LS Disc
WheresWaldo
by WheresWaldo on Mon Dec 06, 2021 4:14 pm
Here is something I didn't know about Pinarello, apparently they only use two different seat post profiles and all but a single line uses the same profile as the Dogma F# series. The only oddball appears to be the Dogma F which uses a slimmer post.
Sent to one of my mount purchasers from Pinarello:
All of our models from the Gan to the Dogma F12 use the same seat post shape and same dimensions. The seatpost on the Grevil or K series bikes will have a “flex” post, but that would still fit into any of the bikes. So, the mount you found should work on your Prince.
The Dogma F, though, has a new, more aero shape and will not fit on any of the previous models.
WheresWaldo
raffit78
by raffit78 on Fri Dec 10, 2021 5:48 am
Is it possible to integrate the specialized swat tool kit and a garmin rear mount in one?
Swat tool kit is compact and uses the same holes as the 3d printed garmin Varia holes. Would be nice to integrate both if possible? Thoughts?
