Camera Mounts and Assorted 3D Printed Parts
aquilinx
by aquilinx
WheresWaldo wrote:
Tue Sep 21, 2021 3:12 pm
@aquilinx,
Which mount is that, I could make it a bit deeper and adjust the angle if you like. I can't do anything until I return home from visiting my parents on October 1.
It's from page 53 of this thread. Thanks!
WheresWaldo
by WheresWaldo
aquilinx wrote:
Tue Sep 21, 2021 8:32 pm
@aquilinx,
I meant what device are you trying to attach. Too many for me to keep track of.
aquilinx
by aquilinx
WheresWaldo wrote:
Tue Sep 21, 2021 9:35 pm
@aquilinx,
Cateye rear light which has a square shaped mount interface
WheresWaldo
by WheresWaldo
Not completely back yet, it is hard to leave elderly parents 2300 miles away. Lots of stuff to take care of at home. I did, however, get an Apple AirTag and designed a module to mount it. Just opened my shipment from Shapeways and it is a bit tight, but a totally workable design. Over the next month I will try to incorporate the AirTag into many of the SWAT, Bontrager, and Shimano Varia saddle mounts.
As far as I know, and I looked on 3D print file repositories as well as on Shapeways Marketplace, I would be the only person designing mounts for the Varia that include a simple clean way to mount an AirTag in the same mount. At some point in the next few weeks I will also pick up a Samsung Tile and see if I can make a further small variation that will mount the Samsung Tile behind the Varia.
Please don't blame me but since adding a mount for the AirTag will require more raw material and take up marginally more space in the printer, Shapeways will be charging more for it. If you don't need AirTag compatibility, there is really no reason to not get your mount now.
WheresWaldo
by WheresWaldo
The first two items, Bontrager and Saddle Rail Mounts
http://shpws.me/SPAT
http://shpws.me/SPAC
WheresWaldo
by WheresWaldo
SWAT version is up now, http://shpws.me/SPDR
kode54
by kode54
Very nice Bud! I may want to upgrade my saddle mount with this version. The saddle mount one you have a link to is the Medium?
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
WheresWaldo
by WheresWaldo
So far I am only working on medium versions, easier to do one thing at a time. They are not simply modifications of the existing models, I am redoing them from the ground up. Still almost identical in design, but not an exact copy with just the AirTag slapped on the back.
I just finished up a Bontrager FLY6ce/AirTag Mount (http://shpws.me/SPHg)
kode54
by kode54
thx!
- Factor LS Disc
WheresWaldo
by WheresWaldo
Just posted a Specialized SWAT Cycliq FLY6 / Apple AirTag mount, http://shpws.me/SQ1i
aquilinx
by aquilinx
aquilinx wrote:
Wed Sep 22, 2021 1:28 pm
@aquilinx,
Are you able to make this mount any time soon or should I just get the old mount instead?
WheresWaldo
by WheresWaldo
aquilinx wrote:
Sun Oct 24, 2021 4:39 pm
You will need to remind me exactly what you are looking for, and maybe include a picture.
aquilinx
by aquilinx
WheresWaldo wrote:
Sun Oct 24, 2021 7:04 pm
I want a mount for cateye rear light with a square mounting interface on my specialized saddle, just like the one showcasing on page 53. But I want the rear light mounted closer to the saddle just like the picture is illustrating.
The original version:
What I want:
WheresWaldo
by WheresWaldo
Thanks @aquilinx
Just an FYI, I am old and senile and your page 53 might not be the same as my page 53 so that is why I asked for details and don't go back through the thread to see old posts.
WheresWaldo
by WheresWaldo
@aquilinx
Take a look at this link, https://a360.co/3Gk1ZbT
It pushes the cateye back 20 mm. But is will be lower than your picture by around 8 mm. I need to do that to make up for anything molded into the shell of the Specialized saddle. Not all of them are completely flat on the bottom. I didn't change the angle from the standard that Speciailized uses on the SWAT taillight.
