Camera Mounts and Assorted 3D Printed Parts
WheresWaldo
by WheresWaldo
@kode54
Sure that is something I can work on, just give me a couple of days.
kode54
by kode54
WheresWaldo wrote:
Tue Jul 13, 2021 12:35 pm
@kode54
THat's great! Will order 2. I changed stems...and this mount has that 22mm spacing which is NOT the K-Edge standard 20mm bolt spacing. Odd. Thx!
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
kode54
by kode54
Bud,
Just a FYI...I bought the 3T Strada Varia mount for seatpost. The holes are made for an M4 not a M5 that is required to bolt up to the back of the seatpost. Also, the countersunk holes are too small (probably because it is 3D printed for a M4 and not M5).
- Factor LS Disc
WheresWaldo
by WheresWaldo
@kode54, thanks for the heads up, I will fix it and reupload a new model. I also shoould have your Di2 model done tomorrow.
kode54
by kode54
WheresWaldo wrote:@kode54, thanks for the heads up, I will fix it and reupload a new model. I also shoould have your Di2 model done tomorrow.
Great. I will reorder the Strada Varia post mount as well. Thx again.
- Factor LS Disc
WheresWaldo
by WheresWaldo
@kode54
Something like this, https://a360.co/36H6Hjq
35 mm diameter
3 mm overall base thickness
22 mm hole spacing for M3 flat head socket screws w/taper
60° outside chamfer
Are these the dimensions you wanted?
WheresWaldo
by WheresWaldo
I will upload both this and the fixed Strada mount at the same time.
kode54
by kode54
WheresWaldo wrote:
Fri Jul 16, 2021 1:24 pm
@kode54
35 mm diameter
60° outside chamfer
Perfect! Thx Bud!
- Factor LS Disc
kode54
by kode54
WheresWaldo wrote:
Fri Jul 16, 2021 1:36 pm
Great! Much appreciated.
- Factor LS Disc
WheresWaldo
by WheresWaldo
kode54
by kode54
Great! Thx Bud.
So the 3T Strada seatpost Varia mount has been updated? The link takes me back to the original one. LMK.
- Factor LS Disc
WheresWaldo
by WheresWaldo
Yes, Shapeways website is kinda strange. They do not deal with iterations very well, so even though it is the new corrected version it might still show the previous version on screen. They will always be at the same link. Their servers take their time re-rendering unless I force it to re-render and that is hit or miss.
Here is how Shapeways handles iterations, lets say I model something, call it RevA, you order RevA, then I revise it and upload RevB, even if I upload it 60 seconds after your order you still get RevA, if it is misprinted (Shapeways fault) and they agree to reprint, it will always be RevA. Now if you place a new order after I upload RevB, you will always get RevB, even if you wanted RevA or any subsequent revision, and so on. It is convaluted but it seems to work for them as they get to be paid for all iterations of a model printed.
kode54
by kode54
They should indicate the actual REV. and DATE so there's no question.
Oh well, ordered. Thx again!
- Factor LS Disc
WheresWaldo
by WheresWaldo
@kode54,
They should do a lot of things, but they don't. Many modellers, myself included have asked for a customizable variant field. We have been asking for over 5 years. They ignore almost all requests for site improvement. That is just one example of many.
kode54
by kode54
Nevertheless, you still provide a great service to the biking community. Thx for that.
- Factor LS Disc
