Camera Mounts and Assorted 3D Printed Parts
wannabefast
by wannabefast
WheresWaldo wrote:
Sun Jan 15, 2023 3:11 pm
CrankAddictsRich wrote:
Sun Jan 15, 2023 1:13 pm
WheresWaldo wrote:
Fri Sep 03, 2021 10:41 pm
If you ever wanted to mount your Varia sideways, I built this mount for someone. I have permission to report the images here.
This is exactly how I want to mount my Varia.... did you ever post this model for sale? I could not find it on Shapeways.
Yep, it is here;
http://shpws.me/SMi8n or this link; https://www.shapeways.com/product/LPX35 ... unt-insert
That looks great! Wish it was available when I ordered my Varia mount, the horizontal orientation is so much tidier than vertical.
CrankAddictsRich
by CrankAddictsRich
wannabefast wrote:
Mon Jan 16, 2023 5:20 pm
Yep, it is here;
you don't have to wish... you can order it now.
tenja
by tenja
WheresWaldo - Please contact me. Need to order another canted SWAT varia mount and can't PM direct now. Not sure why, but can't reply to you on PM. Want to order the exact same as before for new bike.
WheresWaldo
by WheresWaldo
tenja wrote:
Tue Jan 17, 2023 4:43 pm
PM Sent
tenja
by tenja
WheresWaldo wrote:
Tue Jan 17, 2023 5:52 pm
PM Sent
WheresWaldo - I can't reply to PMs due to post count now. I need the Canted SWAT Varia Mount in Large size with the airtag on the front. It works great. No issues. You previously sent me a private link to order. Want to do the same. The prior link is dead now.
WheresWaldo
by WheresWaldo
tenja wrote:
Tue Jan 17, 2023 5:55 pm
PM Sent
http://shpws.me/T6of or https://www.shapeways.com/product/U88RL3SNN
I remember the convo now, I disabled the link because somehow I thought you would let me know if it worked. But since you are wanting another I am going to assume that it does work.
tenja
by tenja
awesome! Thanks. Ordered. Yes - confirmed it has worked perfect since April.
renoracing
by renoracing
I think I'm up to 12 pieces ordered from @WheresWaldo's Shapeways page and thrilled wiht each of them. I used to run seatpost mounted Varias, including some custom ones that he was able to design for me. Since switching to S-works saddles, I now have four of the Canted Swat Varia Mounts on my bikes and love them. They work really well even with my Lezyne Road Caddy saddle bags, for a really sleek setup, and Shapeways prints are far superior to just about every other 3D printed part I've purchased elsewhere.
WheresWaldo
by WheresWaldo
renoracing wrote:
Tue Jan 17, 2023 6:49 pm
Thanks for the kind words. This is why I do this. I love cycling and want to give back to the community. Cycling saved my life and it is very important to me that others get the same joy out of cycling that I have. If I can contribute in a small way, I am happy.
bsharp77
by bsharp77
Hi all,
Looking for someone that can design a downtube mounting plate for my 2021 Giant TCR SL frameset to incorporate a Di2 bar end junction box.
I'm building up the frameset at the minute and trying to make everything as integrated and streamlined as I can.
The hole will just about take a junction box ok (some slight shaving off some of the plastic to make it fit in the cavity snugly).
This has been successfully done by CCC Pro Team - they seem to have made their own mount, but it is not available anywhere either physically or as a design file.
Is there anyone here that could have a go at making one of these?!
I can take measurements and photos of both the cavity and the standard blanking plate if it helps at all.
There is another photo of someone who seems to have just cut a hole into the blanking plate and put the junction in there - not as sleek, but still functional I suppose.
Willing to work with someone to get this part right even if it takes a couple of attempts as i'd really love to perfect this little mod.
Any help very much appreciated.
WheresWaldo
by WheresWaldo
bsharp77 wrote:
Wed Jan 18, 2023 4:05 pm
Hi all,
This looks like the stopper plate replacement, would it be easier to buy a second plate and then drill a hole for the Junction Box?
https://www.giantbikespares.com/Giant-T ... il/3-46647
https://www.bike24.com/p2564055.html
bsharp77
by bsharp77
WheresWaldo wrote:
Wed Jan 18, 2023 4:31 pm
Hi all,
Hi Waldo,
Thats what appears to have been done in the second photo above.
I have a couple of blanking plates on order from Giant Bike Spares, but they are backordered for 2-3 weeks.
However it wouldnt be anywhere near as clean as the mount as shown in the first photo.
They have created a deeper mount, raised up from the frame which allows for the junction box to be sunk properly into the faceplate and creates a much better streamlined finish. The original Giant blanking plate is very thin and wouldnt allow any kind of finish like this (as is apparent from the second photo as the junction box sits "on top" of the blanking plate with the hole drilled into it).
If theres any magic you think you could work on this please do let me know - i'd be happy to send a blanking plate and a scaled photo showing the opening on the frame.
WheresWaldo
by WheresWaldo
@bsharp77
I would have no issues buying a blanking plate, but for some reason Giant has very little presence in the U.S., especially in my part of the mid-atlantic states. I have one Giant dealer about an hour away from me and I would venture a guess, that I would have just as long or maybe a longer backorder time getting the plate from them.
I called the local dealer and they are checking with their Giant rep to see if the part is available in the U.S. I probably won't have an answer until tomorrow.
bsharp77
by bsharp77
WheresWaldo wrote:
Wed Jan 18, 2023 5:16 pm
@bsharp77
Would scale photos of the blanking plate and the cavity position on the frame be enough for you to have a go?
I imagine it's not the shape that will present the problem, but rather aligning the hole to match exactly.
WheresWaldo
by WheresWaldo
bsharp77 wrote:
Wed Jan 18, 2023 5:31 pm
@bsharp77
I called the local dealer, they are contacting their Giant rep to see if the part is available in the U.S. I might have an answer by tomorrow. With the cover in hand I can see what structure Giant placed on the back side of the cover and what I might need to work around. It would be easier if it was in my hands. We will see if that is possible. I will likely still need photos, to see what it looks like in the hole/downtube.
