TobinHatesYou
by TobinHatesYou on Mon Oct 24, 2022 12:04 am
cheapvega wrote: ↑Sun Oct 23, 2022 11:43 pm
I have a question about narrower bars and stem length. Basically, do I have to compensate for narrower bars with a longer stem? I'm guessing I'd have to compensate for half the bar width, so going from a 42 to a 40 would require a 10mm longer stem. I'm also a little worried about knee to elbow interference as I already have some with 42cm bars.
It's not going to be a noticeable difference going from 42cm to 40cm if you think about it. You're creating a triangle using your arm length as two sides and the third side is 10mm. The reach difference is going to be a fraction of a millimeter.
Now if you go from 44cm to 38cm, then you might consider changing stem length, but even then it depends on your shoulder width and whether you can roll them forward, drop or shrug them.
stalkersk
by stalkersk on Thu Oct 27, 2022 10:43 pm
toshi wrote: ↑Thu Oct 27, 2022 5:09 pm
Something I've noticed is that while manufacturers will list bars as available in 36cm widths, distributors/retailers don't seem to offer them. Example:
Pro PLT Compact Ergo Alloy.
Has anyone seen this particular bar in stock anywhere, in 36cm?
IMO, it's market related, I need to soruce them from germany, locally no option to get anything under 40/42 from shimano.
vgcl
by vgcl on Tue Nov 15, 2022 3:39 pm
NordicSal wrote: ↑Sun Feb 14, 2021 10:50 pm
I am coming from 44's, can't decide whether to just go for the 38's straight away or be "reasonable" and do the 40's.
Same here. I'm 1.88m (6'2") and measure around 40-41cm between shoulder bones. 44 fells huge, my wrists twists a lot outwards to compensate. Seems that my most natural position is bending my elbows a little, with my forears pointing inward, bringing my hands closer together.
What you did end up getting? How was the experience?
Tifosiphil
by Tifosiphil on Thu Nov 24, 2022 11:15 am
Mortecouille wrote: ↑Fri Oct 28, 2022 7:16 am
Prime Primavera 36cm are back in stock.
I'm interested, but bothered by the absence of flared drops.
That's what made me go for the 38cm in the alloy and I just tip my hoods in 1cm each side to make it 36cm
Edopizzo
by Edopizzo on Wed Nov 30, 2022 10:35 am
I have changed from a (38 hoods, no flare, 75mm reach) Deda Zero 1 compact round bar to a (36 hoods, 40 drops, 102mm reach) Pro Vibe Aero Pursuit and 2cm shorter stem. I feel like the difference is huge as the aero bar is much more comfortable in the aero hoods position as it's flat so it doesn't hurt the forearms and the 2.5cm reach increase helps because the contact point on the forearms is much closer to the elbows compared to the previous bars when in aero tuck. Also I've turned in the levers so the tips are 30cm apart but it's 40cm at the drops so it's still manageable in sprints and descents.
I think the biggest aerodynamic improvement an aero bar can offer is not the airfoil shape but the ability to rest the forearms on top of them for longer. I also believe aero bars should have a reach above 100mm so there is less leverage on the forearms when in the aero tuck, only penalty will be the necessity to run a shorter stem. Also with longer reach flare and front-sweep are necessary for sprinting to not strike the tops with the forearms.
Only Speeco makes a one piece barstem with similar dimensions, even Pro doesn't offer these bars in carbon. I think that more manufacturers will make long reach aero bars in the future
NordicSal
by NordicSal on Mon Jan 02, 2023 12:26 pm
vgcl wrote: ↑Tue Nov 15, 2022 3:39 pm
Sorry I never saw your question. I ended up getting Aerofly II in 40 cm. I am really happy with it, if anything I would wanna try narrower, but it's working very well for me. I am 1.98m and measure maybe 42 between my shoulder bones (really really skinny though)
loudtiger
by loudtiger on Wed Jan 04, 2023 9:06 pm
just picked up some 38cm specialized bars off ebay to try. i've used 42cm bars the last 10 years so it'll be interesting to see the difference. that said my fixed gear does use 40cms. if these work out i'll look for a nice carbon bar to switch to. currently using FSA SL-Ks.
