Cervelo R2 (7.18kg...for now)
prebsy
by prebsy
Final product before I sold the bike:
Build List as shown:
Frame-Cervelo R2
Fork-Cervelo R2
Headset-FSA
Seatpost- FSA SL-K
Saddle- Specialized romin pro (155mm)
Stem- bontrager RXL 110mm (-17)
Handlebar- 3t Rotundo pro (42cm)
BB- FSA PF30
Crank- FSA bbright Gossamer
Chainrings- KCNC K5
Shifters- Campagnolo Record 11
FD- Campagnolo Record 11
RD- Campagnolo Record 11
Brakes- KCNC C7
wheelset- Farsports 60x25 carbon clinchers
Cassette- Ultegra 6800 (11-28)
Chain- Ultegra 6800
Tires-Maxxis Comet (sponsor correct :lol: )
Tubes- Kenda 80mm
QR's- BHS Ti
Bottle Cages- Shimano Pro Carbon
Bar tape- Renfrew Hocky Tape
Pedals- Ultegra 6800
headwind816
by headwind816
Oooo ... this should be good. Please tell us what the rear max tire clearance? I have read read about the fork (28mm tire clearance report).
I like the white scheme and cannot wait to see your final build.
prebsy
by prebsy
Right now I'm thinking a 25 on a wide rim should be good front and rear. A 28 on a wide rim should work in the front but I do not think it will work in the rear.
deleted the quote. this is a reply. please use the reply button. Thanks FB
GT3RS
by GT3RS
Bike looks great, love the simple colour scheme. Is your bike a 58cm - I'm guessing approx 1050g without BB (doesn't seem too bad with all that paint).
prebsy
by prebsy
54cm
1143 is for the frame with every last little piece on it. I am assuming at least 100g for the BB since it is greased up.
I would guesstimate 970-980 for a painted frame with nothing on it.
Norregard
by Norregard
That's definitely not a 58. Headtube length is way too small for that. I'm guessing that's a 54.
EDIT: should refresh before posting!
justkeepedaling
by justkeepedaling
BB is definitely heavier than 100 grams.
prebsy
by prebsy
Not sure where you are getting that from. An FSA PF30 bb is 84g claimed
Valbrona
by Valbrona
Nice. Anything with such an apparent slack seat angle in the smaller sizes gets my approval. And nice cooker too. Better than those built in things.
Bluemoon17
by Bluemoon17
I like these a lot, very nice. Can't wait to see how it turns out in the future.
justkeepedaling
by justkeepedaling
prebsy wrote:Not sure where you are getting that from. An FSA PF30 bb is 84g claimed
http://www.fullspeedahead.com/products/ ... t-adapter/
Wrong
AFAIK, the lightest BBright BB is 91 grams from THM
Last edited by justkeepedaling on Sun Aug 17, 2014 7:15 pm, edited 1 time in total.
prebsy
by prebsy
Dude it's not an adapter its a pf30 bb on a bbright shell with a bbright crank.
justkeepedaling
by justkeepedaling
Didn't know that you could use any pf30 bb for bbright
goodboyr
by goodboyr
The only issue that makes a pf30 a bit special for bbright is the need for a longer connecting tube between the two side of the pf30 bb. That would prevent water ingress into the back side of the bearings. So a normal pf39 with a shorter connecting tube might have a gap where water can enter. Its not a big deal. The bearing cups are the same.
prebsy
by prebsy
Swapped out the stock saddle for my Romin. The hockey tape is awesome on the bars. I swapped the stem from a -20 to a -16 for now. I thought I could live without my KCNC funny rings but I didn't last a week without them.
The weight is up right now but should come way down when I get my tubulars back from the shop this week. I still need to decide what direction to go with the crank, it will be one of the most important parts in pushing the build to 6kg.
