No cheap lightweight thru-axles? Seriously?
InDustWeTrust
by InDustWeTrust
Any news on this topic?
Klaster_1
by Klaster_1
InDustWeTrust wrote:
Mon Feb 18, 2019 6:06 am
J&L thru axles, but not available for some forks/frames.
jfranci3
by jfranci3
I just sent messages to J&L via ebay about my Trek L123 (why can't they just describe the sizes with the code??) TA. He indicated they'd do it, but on the second message when I asked to order, he got his wires crossed. He might be too busy to.
maddog 2
by maddog 2
what njee20 said. MTZoom are decent weight and not expensive.
ms6073
by ms6073
I use Robert Axle Project thru-axles, especially since they have a nice selector to ensure you order the correct axles.
bm0p700f
by bm0p700f
bm0p700f
by bm0p700f
MichaelB
by MichaelB
ms6073 wrote:
Wed Feb 20, 2019 4:06 pm
I used them to work out which one I needed. To buy through them meant it was A$90 landed in Oz (purchased direct) or about A$95 if purchased through a local retailer in Oz.
Then found these from Wolf Tooth. I needed the 167mm length with 12x1.0mm thread, and this was one of the few affordable ones I could find.
42g for A$66 shipped (purchased through a local retailer). Their US site lists them for USD $39.95
jfranci3
by jfranci3
jfranci3 wrote:
Mon Feb 18, 2019 10:52 pm
J&L put the axles up on ebay that I asked for. They came in and were as described. Recommended.
MikeD
by MikeD
What lube should be used on thru axle threads? Would antiseize be better than grease?
jfranci3
by jfranci3
No, anti seize is just grease with finely ground soft metals in it for high temp environments. The heat degrades the grease, but not the soft metals which are left behind. Use whatever grease you have.
DonutBoy
by DonutBoy
alber84
by alber84
here the fat is used with teflon and it goes very well
