Trek Emonda SLR 10, Thoughts?
Kupepe
by Kupepe
https://www.youtube.com/watch?v=U5guAiwBWqI
Guru Photon HL 4.6 kilos 2010
Chader09
by Chader09
Kupepe wrote:https://www.youtube.com/watch?v=U5guAiwBWqI
From the vid: "747g for 54cm frame"
Looking at just the frame, the Emonda (690g for 56cm) can still beat the Guru assuming equal builds.
I didn't bother to look up Guru's warranty or weight restrictions, but those could be worth comparing too.
kenshinvt
by kenshinvt
mpulsiv wrote:On the SL 6 they use their normal seatpost, not the SLR version. The normal one i have on my own Domane, 148gr for the 175mm version.
Just to revive this, can anyone provide weights on the 135mm and 175mm 20mm offset seat caps for the SLR? The new version with the red anodized clamp.
Trek does not have weights listed yet but the part is available separately. This is of interest to Boone CX, Domane, and madone owners who might like to lighten up the existing post. It wouldn't be worth it though if the weight difference is negligible.
wkwt
by wkwt
They say the SLR seatmast with ears is 119g. So just a difference of 30g with the 175mm and likely less difference with the 135mm.
Other thing I've noticed is it seems less of a "ride tuned" (more vibration) ride with the longer 175mm mast as there's more overlap of the mast and seat tube, but just a guess.
kenshinvt
by kenshinvt
wkwt wrote:They say the SLR seatmast with ears is 119g. So just a difference of 30g with the 175mm and likely less difference with the 135mm.
Thanks! is that confirmed the 175mm since the length isn't listed in that graphic? My assumption was that the shorter 135mm was the standard spec (at least it was with my boone, had to buy the longer).
wkwt
by wkwt
I think the weight listed is for the stock 135mm SLR mast. I meant that it is only 30g lighter than the standard 175mm non-SLR mast that you quoted in your last post. For me, not sure if it will be worth the $150-200 they will charge...
kenshinvt
by kenshinvt
wkwt wrote:I think the weight listed is for the stock 135mm SLR mast. I meant that it is only 30g lighter than the standard 175mm non-SLR mast that you quoted in your last post. For me, not sure if it will be worth the $150-200 they will charge...
The older non-SLR cap is ~118g for 135mm, ~148g for 175mm, actual weights. The official weights that Trek lists for them are 120g and 140g, respectively. The SLR version of each, which runs $50 MSRP higher, has no listed weights for either length.
If the above was the SLR 135mm, then it weighs the same as the old version.. which wouldn't make sense (why even have another part number?). If it is the 175mm length, then it is indeed 30g lighter, which isn't bad for the price difference. But it would also be unusual as Trek seems to most often spec a 135mm as stock (I'm guessing this one gives a more common adjustment range), so I would assume 135mm if (like in that chart) nothing is listed.
djconnel
by djconnel
I suppose the seatpost is non-transferrable, but otherwise the Madone would be only 30 grams heavier.
djconnel
by djconnel
Impressive build list but you could do just as well on your own a lot cheaper than the full build price for the top bike.
On the comparison with Madone: Peloton Magazine called it the liveliest Trek they've ridden, much livelier than the Madone. So take that for what it's worth...
headwind816
by headwind816
djconnel - which version did the magazine test? Did it define lively? I am eye balling a SL frameset.
wheelsONfire
by wheelsONfire
690g is the H1, i wonder what H2 weight is? Anyone?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
KWalker
by KWalker
djconnel wrote:Impressive build list but you could do just as well on your own a lot cheaper than the full build price for the top bike.
You're missing the key point of buying the build: the entire build is warrantied by Trek. You won't be calling and emailing some German dude if and when your shit breaks. Also, Trek wouldn't put out something risky so you're buying piece of mind as well.
Gramz
Failed Custom Bike
wkwt
by wkwt
wheelsONfire wrote:690g is the H1, i wonder what H2 weight is? Anyone?
SLR frame H2 sz 52, 730g with internal cable sleeves, RD hanger, and handful of stickers on.
Fork is 290g
Can't imagine their claims of the 56 being on anything but the vapor paint.
headwind816
by headwind816
Wkwt - what shop is that? Any weights for the SL?
Ozrider
by Ozrider
On Treks website they list a 56cm SLR 9 at 6.1kg without pedals or bottle cages priced at AUD $12 999.00. This is with full Dura Ace and Bontrager Aeolus 3 clinchers. With pedals and cages you are looking at 6.35 - 6.4kg dependant on pedals.
In comparison my 2010 Parlee Z5 weighs in at 6.1 - 6.4kg ready to ride with SRAM Red and Enve post, stem and bars, Speedplay. Ti pedals, Arundel cages and Garmin sensor / mount.
Not much incentive there to swap over. Admittedly the Trek Emonda would be about 200g lighter with Tubulars and you could fit the one piece XXX integrated barstem found on the SLR 10 and save another 118g for a RRP of $599.
I will be test riding one in a week or two to compare how it rides and handles in comparison to my Parlee and Madone.
Parlee Z5, Trek Madone, Colnago Dream,
Ozrider - Western Australia
