Are carbon wheels still noisy?
derek
by derek
I test rode bikes with carbon wheels (around 40mm and 50mm wheels) two years ago and the wheels made it sound like you were riding a fully wooden wheels. Do all new carbon wheels sound the same? I really like the look of fully black wheels but don't like the extra sound carbon wheels make so I've also been thinking about Mavic Ksyrium SLR WTS. But those cost about twice as much as chinese carbons :p
Zen Cyclery
by Zen Cyclery
If you want quiet braking you should go with an alloy rim, or go disc.
Zoro
by Zoro
I hope so.
HillRPete
by HillRPete
derek wrote:I test rode bikes with carbon wheels (around 40mm and 50mm wheels) two years ago and the wheels made it sound like you were riding a fully wooden wheels. Do all new carbon wheels sound the same?
If you mean the hollow sound of carbon rims, shallower ones will have that less than the deeper ones.
If you mean squealing, lots of people, including myself, have had success using Reynolds blue pads on "generic" carbon rims. But of course SwissStop has been busy too, since the yellows have been introduced -- I've just not tried anything newer from them, because Reynolds are cheaper and perform good enough. A lot depends on the brake caliper, too. Stronger (often heavier) ones many times work better and vibrate less -- less noise.
derek
by derek
I mean the hollow sound. I would get 38mm wheels max. Is there big difference in sound between 38mm and 50mm?
I live in pretty flat country so I'm not that worried about the braking sound.
Butcher
by Butcher
I'm no expert, but all carbon wheels seem to be louder. Why, my guess is that with the thinner material for the same strength, it would be more like a drum. Since noise is just a vibration you can hear, the thinner material just vibrates a little more in a range you can hear.
Again, I'm no expert and can just barely even ride a bike.
audiphile
by audiphile
I routinely ride sets of shallow alloy, 45mm deep carbon and 65mm deep carbon wheels. While the alloy wheels are somewhat quieter, I would never say that the 45 or the 65 are terribly loud. I think the sound may vary based on whether the carbon on the wheel is a fairing or structural (could be wrong), but regardless never found them to be terribly offensive.
bm0p700f
by bm0p700f
When I am going properly my breathing is loader than the hollow sound and so is the wind noise and the tyre noise.
jooo
by jooo
If it's that much of a bother, you could investigate some foam-core rims.
Spaetzle
by Spaetzle
Mine Are quiet.
derek
by derek
jooo wrote:If it's that much of a bother, you could investigate some foam-core rims.
Have to look on those.
