Garmin Edge 500 Battery Replacement - How to / DIY / Guide
Miller
by Miller
I did go ahead and replace the battery in my 520. I got the battery from batteryupgrade.co.uk for £21.49 and I bought a metal and plastic spudger (great word) set from ebay for £2.89.
Having watched a youtube video I went ahead and pried off the front screen. It is glued firmly in place but if you work round the edge methodically, it eventually comes off although some force is needed. Take care at the bottom RH corner where the ribbon cable lives.
Next, unscrew the circuit board and lift it out. Unplug the battery from the circuit board. The battery is stuck to the case but can be easily pried out.
I cut the wires from battery to speaker then soldered the speaker wires to the new battery. The new battery came with the necessary plug and wires. The old battery is 700mAh but the new one is rated as 600 mAh.
After this I reassembled. The Garmin started up fine but... no sound. I opened it up again and found the plug was slightly loose. Reassembled and all was good with those familiar beeps. To replace the screen I put a little bit of 'No More Nails' DIY glue round the edge and put a weight on the thing till the glue set.
It will be interesting to see how the battery life is from now on.
kode54
by kode54
nice job! its a shame that Garmin is using a one-time foam seal. the one in my Edge 810 has a silicone reuseable seal.
i also noticed that there's no second circuit board for the speaker like on the 810...which is why you probably have to splice the wires with the battery.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
miltmaster3
by miltmaster3
πατα τραβα ρε
nismosr
by nismosr
anybody try replacing the battery on the 820
2020 Colnago C64 Mapei - SR12 EPS - LW Meleinstein
2022 Ridley Kanzo Adventure Rival/GX AXS
2021 Basso Diamante SV - SR12 Disc EPS - Bora WTO 60
2022 Basso Palta 2 - Rival/GX AXS - Zipp 303s
TonyM
by TonyM
nismosr wrote:
Thu May 23, 2019 7:28 pm
As I had the problem with the display being slowly defective (the edge started to "fade out") Garmin offered me a 50% discount on the battery replacement if I wanted to have this done beside the replacement of the display. Actually I received a refurbished Edge 820. I paid US$64 for the display and battery replacement.
Bonus for me was that I received a refurbished Edge 820 which was way newer than mine (I bought mine almost after the release). Everything is going much faster.
But hopefully my old Edge 820 will not be repaired and sent to a Garmin customer as refurbished.
Lozaen
by Lozaen
If the new battery comes with plug, why not simply pin out the two speaker wires and pin them in the new plug? Would save the soldering part.
In the Tour Forum it was stated by one member, that between the pcb and the case there would be more space than required. Possibly enough to fit in two batteries. Can anyone comment on that statement?
Interested in buying Carbonsport Lightweight wheels with broken spokes.
BMC Teammachine SLR01 Disc Team 2018|Ridley Helium | Kuota Kross|Cannondale Scalpel 29 Hi-Mod
g32ecs
by g32ecs
I just wanted to bump this as I replaced my battery+back housing last night on my 1000. Took less than 5 mins. Cost me ~ $65 CAD I think. Shipping was 1.5 week from AliExpress which was impressive speed
My old battery was only lasting me 10hrs without turn by turn, backlight to lowest. This is reduced to 8hrs with turn by turn. My power button was also kaput and USB socket loose. I thought of buying a new computer this season but I wasnt gonna give up on it without trying.
Miller
by Miller
My turn to update this thread. My Garmin 820 has had increasingly poor battery life this, er, last year. It would be exhausted in a 3-hour ride (so might I be, but that's not good enough). I was thinking to replace the battery myself but the new batteries I could find were £20 or more. Then I found www.satnavspecialist.co.uk who promised to do the whole job for £34. I posted the 820 off to them and a week later got it back with a new battery inside. There's a fiddly job I didn't need to do. Trying it out this weekend it's using 10-12% of charge per hour which is a massive improvement. So, thumb-up and a recommend to Satnav Specialist in the UK.
naska7942
by naska7942
It was a very good guide. I am learning a lot
