Garmin Edge 500 Battery Replacement - How to / DIY / Guide
vtspot
by vtspot
Appreciated for the information. :)
wombatk
by wombatk
I found this very useful when replacing my Edge 500 back cover, to fix an Enter button that had cracked up.
The only extra trick I had to work out was how to remove the speaker. I tried just picking out the glue around
the edges of the speaker, but it still wouldn't budge. So then I used a 3 ml hypodermic syringe to squirt about
0.5 ml of acetone around the edge of the speaker. After 30 seconds, I could then slowly prise it up with
a bent-nose tweezer.
To reinstall the speaker, I used some silicone sealant, dabbed just around the edges of the speaker to mimic the
pattern used previously.
Cheers
9tarmac
by 9tarmac
Great thread, thanks for the info.
finnrambo
by finnrambo
Thanks! Now I just have to figure out if it's possible to program in custom notification sounds...
Canadian Junior racer and Product Reviewer: Finn Blackburn
Blog: https://finnblackburncycling.wordpress.com/
outnumbered
by outnumbered
Juanmoretime wrote:Thank you for.honoring my request! :wink:
Now this is what weight weenies is all about.
It's a very useful post for sure.
For many more WW points he could have mentioned the weight difference between the two batteries though :)
kelly07
by kelly07
very good skill
Chiva
by Chiva
I'd like to thank you Prendrefeu for starting this thread and giving such a detailed step by step set of instructions. I did this last night without any problems thanks to your pictures and instructions. I really appreciate all the great members of this forum.
NoS
by NoS
thanks for the info :)
droid1973
by droid1973
Thanks for the guide!
Milese
by Milese
Ive got a Garmin Edge 500 that was replaced outside of warranty (presumably for a refurb) about 12 months ago.
In the last week the battery usage has suddenly become awful, and the temperature is reading about 12 degrees C too hot.
Since charging on Wednesday it was completely flat within less than 3.5 hours of use, and this morning it used 29% of the battery in 40 minutes.
Ive done a bit of googling and can see that battery replacement is possibly DIY, but it sounds like that solves the problem of gradual battery decline for old batteries. Others who have reported the temperature problem have changed the battery and the problem has stayed, presumably because the problem is linked to some error in the unit causing high battery drain that both flattens it and heats it up.
Any advice? Ill do a master reset later, but dont hold much hope.
This is my 3rd failed Garmin, and Im loath to pay for another out of warranty replacement if this one is terminal. Are the 510s more reliable?
Markmoddy
by Markmoddy
Very helpful cheers
gilco
by gilco
just what I was looking for ... thanks
Jesper64
by Jesper64
I don't have a Garmin 500 but always love to see tear down guides. Thanks :thumbup:
tr85858
by tr85858
Any new sourced for edge 500 batteries with higher capacity than original?
thanks
boramee
by boramee
Awesome. A very nice guide, thanks! :-)
