AX Lightness Vial EVO
lannes
by lannes
Can you give us a picture of the head set, stem etc.
sakattack
by sakattack
lannes wrote:Can you give us a picture of the head set, stem etc.
This is the next step,to give you pictures of the bike,as soon as i find
a camera.Mine unfortunately is broken so please be patient.
Thank you for your response wheelsONfire.The dust cap is seated properly
where it should.I can feel the play when i brake hard with the front brake so
i spot it in the upper headset bearing.I guess i'll send an email to AX.
idinfo68
by idinfo68
Hello,
What do you think about this pictures ?
_____________________________________________________
No crash, no impact...
Discovered after a thorough cleaning
Normal use after 5 000 kms
Thanks for your answers
hornedfrog
by hornedfrog
Hello,
Definitely a impact of some sort. Whether is was some major chain slap or a piece of debris, that doesn't just "happen" by itself. Sucks, I know, but it is not a case of frame failure.
micky
by micky
The line seems to "clean" to not think about an impact; perhaps when storing it or moving inside/out of the car?
On the good side is that it seems in the middle section of the seat stays, so it should be easily fixable.
wheelsONfire
by wheelsONfire
I had a chain slap but it is no way near that damage you have.
You know, it looks like your lower pulley wheel has been slammed against the chainstay?
I would send this picture to Ax Lightness. Your frame can be repaired!
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
kode54
by kode54
could be from debris on the road. i've hit a few things that flip up and hit my frame....with no damage. could be from that.
- Factor 02 VAM Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Factor LS Disc + DA9170 + Enve G23 CK CL hubs
- Repurposed Guru Praemio R w 3D disc dropouts + DA9170 + Enve G23 CK CL hubs
prendrefeu
by prendrefeu
By the way, is that paint retro-reflective? or just silver?
idinfo68
by idinfo68
Just silver, normal paint.
No transport in a car.
"You know, it looks like your lower pulley wheel has been slammed against the chainstay?" >> No possible, 2cm too far
"could be from debris on the road. i've hit a few things that flip up and hit my frame....with no damage. could be from that." >> the hole is too big or long for this kind of damage
I'll send pictures to Ax to see what they can do...
Thanks
rmerka
by rmerka
idinfo68 wrote:"You know, it looks like your lower pulley wheel has been slammed against the chainstay?" >> No possible, 2cm too far
Other than the frame looks identical to this http://weightweenies.starbike.com/forum/viewtopic.php?f=14&t=122234&p=1040155#p1040155. Which turned out to be a derailleur swinging up and smacking the frame.
BlackMadone
by BlackMadone
It looks like your derailleur smacked the bottom of your chainstay while riding but you have Di2 so I don't understand why.
tinozee
by tinozee
Looks like egg shell fragile.
xena
Banned
by xena
Be interesting to see how long the repair will take if you send it back to AX.....maybe quicker to get a local carbon repair to fix it with the approval of AX .
BlackMadone
by BlackMadone
When you're talking about super lightweight carbon fragile is to be expected. I would only have AX fix this, they know their carbon.
Mario Jr.
by Mario Jr.
Good luck. Rumors here at Eurobike is that AX has closed because of financial reasons...
