135mm OLD frameset, 130mm OLD wheels
Martin1977
by Martin1977
is there any problem to use Ridley X-Fire for 135mm rear hub OLD with wheels laced to Novatec hub, which is 130mm OLD? Unfortunately new 135mm OLD Novatec hubs are not available :-( Shall I order wheels laced to older 130mm OLD hub?
thanks
Martin
ms6073
by ms6073
Martin1977 wrote:Unfortunately new 135mm OLD Novatech hubs are not available :-( Shall I order wheels laced to older 130mm OLD hub?
Did you try Bdop in Taiwan?
Ragamuffin
by Ragamuffin
If that doesn't work, you could probably just used 2.5mm spacers on either side and that should be fine.
