Max tyre size for CAAD9 + Crud road racer mudguards + 4000s
parajba
by parajba
Hello weight weenies...
Bit of a peculiar question and possibly difficult to answer unless you tried yourself but can I mount a Conti 4000s size 25 on a CAAD9 with Crud road racer mudguards? I have been using these mudguards with Conti 4000s size 23 for years and they are very good.
I was looking for even more comfort and grip for those lazy commutes...
Thanks heaps
olebole
by olebole
Hi!
I can fit 28c schwalbe duranos, on fulcrum 5 wheels, quite easily to my size 54 caad9.
Dunno if this is any help to you but I think 25c with cruds should work.
parajba
by parajba
Hi Oebole,
Thanks for your help, my CAAD is also a size 54.
RichTheRoadie
Tinker, Taylor, Tart
by RichTheRoadie
You'll be lucky Manny - it'll be tight, and you'll get a lot of noise.
parajba
by parajba
Hi Rich!
Do you mean you tried and it works? What noise are you referring to? General debrief picked up while cycling that gets stuck on the tyre and rubs against mud guard to very limited clearance...? I know there is only one way to find out but I'm to lazy to buy the 25c, try them and then sell them on eBay if they don't work :-/
RichTheRoadie
by RichTheRoadie
The guards will rub regardless - they're not proper mudguards so it's unavoidable. 25c tyres will only make that worse.
My advice is don't bother trying. The guards are designed for 23c tyres anyway.
