Chainsuck on brand new Di2 9070 Venge Boonen Ltd build
ghisallo2003
by ghisallo2003
Small ring, small cog. Mech must have tension with clean chainline and sufficient gap between chain and jockey wheel / cage.
xclemjustinx
by xclemjustinx
^incorrect way to setup your bike for the correct chain length
ghisallo2003
by ghisallo2003
Try reading campag manual: 10-15mm gap at small; small to set length.
If you dont have tension and chain touches jockey wheel then you surely do have a chain that is too long.
xclemjustinx
by xclemjustinx
That's not a campy chain and that's not a campy bike.
ghisallo2003
by ghisallo2003
Yes thats right, my mistake, It probably works in a completely different way.
Calnago
In Memoriam
by Calnago
Doesn't matter if it's campy or not. Principle is the same. Like @ghisallo2003 said, "If you dont have tension and chain touches jockey wheel then you surely do have a chain that is too long".
Just from looking at the picture, it seems that dropping the chain down to the smallest cog would create a situation where the derailleur is not providing any tension on the chain. Very easy to check.
However, the things @thisisatest suggests would probably be a more likely cause for the chain suck, particularly as it relates to the interface of the crank spider and chainrings. I'd check all that VERY carefully... the chain's gotta be catching somewhere, and it doesn't take much.
maxxevv
by maxxevv
xclemjustinx wrote:How can you determine if his chain is too long or too short from that picture? In order to see if his chain is the correct length you must put it in the big chainring and the smallest cog in the rear and see if the pulley wheels are 90 degrees of one another.
Its just a guideline that will work with some but NOT all chainring and cogset combinations. It will work well with a standard 39/53 and 12-25 setup. BUT ... try doing it on a 36/52 and 11-28 setup and you get into problems ...
You still need the "small-small" combination check for sufficient chain tension and the "big-big" combination check to check for sufficient chain length (and prevent unnecessary strain on the RD at extreme crossover) to be 100% sure.
If you've wrenched enough bikes ( be it hobby or as a job), you'll see all sorts of funny permutations and their quirks. Most of the people here are making a judgement call based on our own experiences. And why not you wait for the original poster to come back to verify our prognosis instead ??
Andrew69
by Andrew69
ryker wrote:^Yeah check your chain length!
That chain looks waaay too long!
Half way down the cassette and the jockey wheels are already close.
Beautiful bike btw!
tommasini
by tommasini
Agree with many others - a failure by the shop to properly pick the proper chain length......
5 8 5
by 5 8 5
xclemjustinx wrote:^incorrect way to setup your bike for the correct chain length
Using the small / small method means you've got the longest possible chain. It allows you to use a bigger 1st gear cassette (within reason) without having to lengthen or change the chain.
Geoff
by Geoff
How else can you do it? :noidea:
mjduct
by mjduct
According to who?
Thats pretty much the tried and true way for initial setup, Then you check it on the big-big combination and make sure your derailleur span it without getting sucked up in your cassette.
xclemjustinx
by xclemjustinx
What if your rd can only handle a 28 tooth and you just gave the chain the longest possible length? Now what. Having the chain to long can decrease shifting efficiency and can have issues of the chain dropping. The standard is big big without going through the rd pulleys and add one set of links.
xclemjustinx
by xclemjustinx
I've wrenched more bikes the you can fathom and don't give me that "I've been a bike shop owner for 40 years so I know everything attitude."
A standard road bike setup will have the pulleys at a 90 degree of one another. If you are using a MTB then the application is different. I've worked on so many bikes where the chain length was incorrect and the shifting was horrible. Take a look at the installation instructions from Shimano regarding chain install.
http://techdocs.shimano.com/media/techd ... 700387.pdf
by 5 8 5
xclemjustinx, I don't think you get it!
The chain wouldn't be too long, the RD would still wrap the chain.
There isn't an exact / correct chain length - it's a range. That range will function perfectly well.
What happens when the pulleys aren't perfectly vertical when using big / small. Does one "remove" a pair of links or "add" a pair. It's not the exact science that you make it out to be.
Big / big and small / small are accepted methods for chain length. Like maxxevv I use both methods erring towards the longer chain.
