Dengfu fm029 ISP Updated Page 1
brearley
by brearley
My Dengfu FM029 isp frame size 54cm should arrive next week.
Build list as follows
Dengfu FM029 frame and fork Seatclamp upgrade to Ritchey WCS
Super record groupset minus Cranks and brakes
Sram red cranks + Osymetric 54 tooth ring, now sanded with stronglight ct2
Planet x CNC brake callipers
Powercordz swift outer cables
Parlee copy FD clamp
Selle Italia slr Kit carbonio now san marco concor light
Ritchey WCS 4Axis 140mm with Ti bolts
Deda Newton shallow 40cm
Speedplay cromo pedals Ti axles added
Hed stinger 60 wheels with vittoria corsa evo sc front challenge strada rear
Planet x 20mm carbons with continental sprinter gatorskin with chorus cassette Now with Vittoria Corsa SC
Planet x carbon/ti Quick release
Fizik bar tape
kmc x11sl chain
Chainset will be sanded and clearcoated so will be just carbon.
Not sure what weight will be.
This will be for racing not just leisure.
If any of you have any ideas where I could save some weight please let me know.
Edit: 03/04/2014
brearley
by brearley
received my powercordz swift cables today.
full 3m length with liner and bags came to 85g so should save me around 150g over standard campagnolo cables.
FD clamp weighs in at 6g.
looking forward to building up this new bike. hoping to get under 6.5kg
brearley
by brearley
apologies for the poor quality picture I will take some pictures later tonight when it's finished.
need to chop down steerer and seat mast slightly and also gear cables and bar tape.
also require some bb30 spacers so will be finished tonight.
currently fitted with Athena 11 shifters until I get my Super record fixed.
I am also pleasantly surprised at the weight of the compression bung (27g)
upgrade in future will be a new isp topper and ritchey 4axis -17 degree stem
Ltoddokc
by Ltoddokc
Looks nice. I really like the lines on that frame and I'm considering ordering on. I'd really be interested in your review once you have some miles on it. And some good pictures! : )
brearley
by brearley
With training/ climbing wheels
ImageWith race wheels Imagefront end with Powercordz swift cables Image
so I've been away racing and not had time to be on here.
two races and two top 10 finishes so far on this.
finally got round to taking pictures.
Unfortunately until this weekend I cannot give you a weight of the bike as a whole.
frame is very responsive and stiff, handles very well even with the 14cm stem.
not sure on frame weight. I cut 5cm seatpost from original which weighed 16g
cut fork weighed in at 369g
Samuel Sanchez Gonzalez
by Samuel Sanchez Gonzalez
YES YES YES YES Brearley
THAT is how you set a race bike.
Perfect balance, perfect amount of seatdrop, shallow bars, damn you got taste.
With this, you can pretty much put whatever frame, it will look RIGHT
Krull
by Krull
Samuel Sanchez Gonzalez wrote:..........
+1
joshvoulters
by joshvoulters
That looks mean
brearley
by brearley
so the official weights
with planet x 20mm carbons, sram garmin mount + garmin edge 500 = exactly 6.8kg
with hed stinger 60mm carbons, sram mount + edge 500 = 7.02kg
obviously if i were to put the tubs and cassette from the 60s and also changed to a lighter stem (current is around 180g) the overall weight would be somewhere around 6.5kg
currently the planet x wheels are my training wheels so I have to use the conti gatorskin tubs.
future updates coming soon will be. praxis or stronglight ct2 53t chainring (the osymetric is too flexy for crits i feel)
ritchey wcs 4 axis 130mm -17 degree stem.
I have a pair of fulcrum racing ones as training wheels however until I can afford to buy some veloflex master tyres and another chorus cassette i'm stuck with the planet x wheels.
brearley
by brearley
so guys i'm looking to bring the weight of this down. still not tracked down any praxis or stronglight ct2 53 rings cheap?
I've ordered a ritchey wcs 4 axis stem which should knock somewhere in the region of 40-50g off the weight of the bike.
I think a stronglight ring or praxis would knock 50g off.
I did buy a knock off parlee carbon fd clamp however it is quite flexy, has a shiny surface so any pressure on the front derailleur and it slides?
I'd like to get the weight around 6.5kg with the 60mm carbons in and maybe around 6.2kg with 20mm carbons in.
Obviously there is the limiting factor of the frame being relatively heavy I believe.
I've searched before but a different ISP doesn't seem an option as the weight difference is minimal for current options?
I may upgrade axles in my speedplay pedals but we shall see.
any other ideas are welcome
Valbrona
by Valbrona
By the look of if the FM029 is exactly the same as the FM028 but for the internal derailleur cabling. On the FM029 is the headtube 1 1/8" top and 1 1/2" bottom?
brearley
by brearley
I've now taken 65g off my bike with a ritchey wcs 4 axis stem and going back to the sram red 53 ring.
still looking to get the bike down to around 6.5kg with hed stingers in. it's now 6.95kg with hed stingers
feyder
by feyder
Hey brearley, I just received an FM029A today. This will be my first build. What headset did you put on your FM029 and how much prep work was needed to get the HS installed? Also, any issues with the internal cabling?
Thanks. I hope not to pester you too much, so I hope you don't mind these questions.
DRAGON60
by DRAGON60
Can you install the FD carbon clamp with the paste ----would that give it a grip? Just asking but never tried it myself.
It is a beauty----it's got that diamond hard look of a cobra happening. :thumbup:
brearley
by brearley
I don't mind any questions.
I used the headset which came with the frame. No prep needed really. Put the crown race on pushed down fully opening it up slightly with a screwdriver then put both bearings in. once the fork was cut and stem put on the headset could be tightened and since then i've never had any issue with it.
absolutely no issues with the internal cable routing, slid through nicely. Even with the kink you usually get due to the way Campagnolo cables come out the shifter it was fine. I have used powercordz swift cables which add another element to getting the gears to work fine but this isn't really an issue anyway.
I could do with cutting the isp maybe 2-5mm but so far off 5 outings the bike has had top 10s in 4 of those so i'm not too sure.
