AICAN Bungarus installation
Leviathan
by Leviathan
Ive a question about these. In the pack, as well as the aluminum outer, assorted end pieces and the DLC steel cables, is long length of small diameter rubber or plastic tube - whats it for? Its not the lining (which is incorporated inside the aluminum ferrules) and the somewhat unhelpful text and diagram shows it being put after a section of the outer, almost as if its a covering for the cables on the part where they would normally be exposed. For an internal cable run am I supposed to try and feed that AND the cable into the down-tube?
audiophilitis
by audiophilitis
It's supposed to be used for the exposed portions of the cable. With internal wiring, you shouldn't have much use for that black plastic liner.
Leviathan
by Leviathan
Many thanks..
FastforaSlowGuy
by FastforaSlowGuy
I used it to run my rear internally routed brake cable. Smoothed things nicely.
__________
Seven 622 SLX
Colnago C50 Extreme Power
Zanconato CX
newnan3
by newnan3
If I have external routing that go from the front cable stops to the plastic cable guides at the bottom bracket I wouldnt have a need for this plastic tubing correct?
Or should it be run up to the point where the cables enter the cable guides at the bottom bracket?
cerro
by cerro
Where can I get this in Europe? Is it just Fairwheelbikes that sells them?
/jonas l
newnan3
by newnan3
Hey Cerro/Jonas, Greetings from the US.
I occasionally check out your blog.....I like it a lot! Its a good mixture of pictures, content and commentary :)
Keep up the great work!
carlislegeorge
by carlislegeorge
cerro wrote:Where can I get this in Europe? Is it just Fairwheelbikes that sells them?
ebay is your friend....
2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
2012 Parlee Z5 SLi (just because)
2014 Colnago C59 (why not)
Zigmeister
by Zigmeister
eBay Taiwan. They deliver.
