Front derailleur?
Mads Kock
by Mads Kock
What kind do you use for your cross-bikes? I have a small wheel on the frame so I can use both top and bottompull!
I'm thinking about road derailleur because of the weight but maybe the mtb derailleur is better because of the compact chainrings?
Squalo
by Squalo
Record CT, with the pulley. works well with 48/36
Mads Kock
by Mads Kock
CT - is that for compact cranksets?
RTW
by RTW
It is indeed. Slightly more curved than the normal one.
Mads Kock
by Mads Kock
but wouldn't a road front derailleur for compact chainrings be the same as a mtb front derailleur?
simon
Resident Pro
by simon
mtb derailleurs are a bit tricky to adjust, i would use a road derailleur. at the moment i'm using a record one for normal chainrings(no ct)with dura ace 10 speed levers without any problems.
Mads Kock
by Mads Kock
Thanks Simon - I mounted my Dura Ace front derailleur from my roadbike until I find an ultegra (called 3 shops today and they were all out). Merry Chrismas to you, Simon and thanks alot of all your advises through the year! It was been really good!!!
