New shifter clamps in DA 9000?
uraqt
by uraqt
It looks like there are new shifter clamps in DA 9000?
The 7900 ones look much thicker and have different part number?
Anybody weigh 9000, I think the 7900 are posted on the board someplace.
Thanks
C
maxxevv
by maxxevv
They are different as far as I can see. More material cut out for those on the DA9000.
uraqt
by uraqt
That is what I thought!! : )
C
uraqt
by uraqt
No rust!!!! just like 7900
C
Doolop
by Doolop
Just recently got 9000, had 7900 in the past. As a bike nerd one of the first things I noticed about the new shifters were the new clamps! Less material, did not weigh them but I can only assume they are a tad lighter.
CAADEL
by CAADEL
Are those DA-9000 clamps compatible with DA-7900 shifters?
uraqt
by uraqt
CAADEL,
The Shimano website says the nut isn't compatible, but as far as the clamp part, I am thinking that it has to work with all shifters.. I am a Campy 10 speed guy and plan to buy them as soon as the are available in the USA.. : )
C
maxxevv
by maxxevv
The Ti, non-rust properties are nice, besides the weight of course. But issue is ... those bands are expensive!!! Last checked for the 7900 ones, they were about US$108 for the pair !
styrrell
by styrrell
I have some sections of seatpost that are pretty thin and look to be about the correct diameter to use a clamps. One is from kcnc, so its thin aluminum.
he idea is to just and deburr, drill a hole then thread the proper size bolt through and epoxy it in place. Any one try this?
As a point of reference I tried years ago with flat aluminum that I bent and cut, mimicing a steel clamp, but it broke after about 6 months, luckily gently so no issues. The break was at a bend so that will be avoided this time.
cerro
by cerro
Isn't the new 9000clamps same ti-clamps what was on 7970? They have ti-clamps too while the mechanical 7900 had steel. Would like to get those ti-clamps for my Super Record levers :) Nice weightsaving without functionchanges.
/jonas l
by 5 8 5
The 7900 clamps are titanium and very expensive. Discussed here -
http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=99861&start=0
