Making the transition to tubulars
shamrock134
by shamrock134
So I've read the entire thread and in all honesty, tubs sound like faff to me. However, I am still slightly curious to see for myself what the hype is about and keep having this idea that I could get a set of lightweight Chinese tubs purely for cycling holidays.
I currently ride Bora 35 clinchers and I'm very happy with their braking and ride quality when paired with nice clinchers (currently Veloflex Corsa, might switch to Vittoria G+ in the future). I've used them without issue (so far) in Majorca, Gran Canaria and the Pyrenees.
What would you say to convince me to try tubs?
sungod
by sungod
safer, lighter, comfier
shimmeD
by shimmeD
pro
cool
Less is more.
shamrock134
by shamrock134
Compelling arguments! The safety aspect is the main thing that attracts me as it's always slightly at the back of my mind on a mountain descent. Although Boras seem anecdotally to be better than other carbon clinchers for heat dissipation/delamination.
Lighter? Seems to me you just move the 200g you saved at the rim into the spare tub or sealant you have to carry?
I've been eyeballing cheap Chinese tubs. Surely these would have inferior braking to the Bora? I guess the only real option is Bora tubular! :shock:
beanbiken
by beanbiken
shamrock134 wrote:
Thu Nov 15, 2018 11:14 pm
Sorry, that argument doesn't wash with me. I have never carried a spare tub as in the almost 10 years I have been riding tubs exclusively [I definitely don't do big km's though] I have never had a flat. I carry sealant and you carry a spare tube.......... even :D My take on it anyway :)
BB
BB
Coffee & carbon
shamrock134
by shamrock134
beanbiken wrote:
Fri Nov 16, 2018 12:04 am
BB
Doesn't that make you the minority? Most people seem to advocate carrying a pre-glued spare. I even saw one comment in this thread about carrying two! :shock:
Define big km? Several 100-150km rides on a cycle holiday isn't unreasonable. What would you guys bring along if say doing 7 days in the Alps or Dolomites?
sungod
by sungod
i use a light tufo as a spare tub, < 160g
if i'm on clinchers, i'd be carrying a spare inner tube and puncture repair kit, tyre lever, tyre boot, that may not be 160g but it's well on the way, and of course the clincher wheels are much heavier (my lightweight tub wheels are < 940g)
shamrock134
by shamrock134
sungod wrote:
Fri Nov 16, 2018 4:15 pm
Say I hypothetically bought some 38mm deep 25mm wide, U-shaped tubs from China. Would there be any hypothetical risk in running 23mm Veloflex Carbons or a 23mm Carbon front with 25mm Arunberg rear? I suppose tubs should always match the rim width unlike clinchers?
sungod
by sungod
really depends on the exact tyre/rim and how they match
taking extremes, if the tyre is too small, the edges of the basetape will not be stuck to the rim, but with 23 on 25 i wouldn't think you have a problem there
in aero terms, a bit narrower is fine
r3m
by r3m
I'm new with tub wheels. I bought a Lightweigt ML second hand and i ask myself which tubs choose between Corsa G+ (23 front 25 back) or Veloflex Carbone ?
I roll today on classic GP4000S2 23/25 and i use my tuby wheels for granfondo with good weather.
Thanks for you help.
Pinguin
by Pinguin
r3m wrote:
Thu Nov 22, 2018 2:25 pm
Veloflex Carbon is only 23 mm,so for the rear if you want 25 mm is Arenberg
These are good tires and not much difference to Corsa G+
Look at the Corsa CX,they are cheaper and also good to ride
sungod
by sungod
i would go with the 22mm veloflex sprinter (or veloflex extreme if you want black sidewalls) on the front
the handling in strong wind changes with a wider tyre, the extra 1mm of a criterium/carbon makes a big difference
on the rear the wider tyre does not affect handling, personally i prefer 23mm - so i run sprinter front and criterium rear
Wookski
by Wookski
shamrock134 wrote:
Thu Nov 15, 2018 7:23 pm
Whether you try tubs or not doesn’t impact us. If you’re already worried about the faff then they’re probably not for you.
This is coming from someone who rides tubs exclusively.
shamrock134
by shamrock134
Wookski wrote:
Sun Nov 25, 2018 5:59 am
So explain to me objectively why you ride tubs exclusively, please.
calleking
by calleking
I went for a ride on CLX64s with Corsa G+ 25mm tubs a week ago. I normally run Enve 4.5s with Power Comps and latex tubes. I was actually disappointed as I expected the ride to be much comfier but it was actually the opposite. Pressures were right for my weight. I can see the point of tubs since they are lighter and more safe but the comfort argument must be a thing of the past. Modern wide clinchers paired with quality tyres and latex tubes are so good these days.
Are the Corsa G+ considered harsh compared to say Veloflex?
2018 S-Works Tarmac SL6 Sagan Superstar DA Di2
2016 Focus Mares CX
2016 Grand Canyon AL 8.0
Retired: 2014 Crux Elite, 2017 Cannondale Slate Ultegra, 2016 Aeroad CF SLX 8.0 DI2
