Powertap G3 build on 38mm clincher carbon rim
iboc23
by iboc23
Hi!
For an 150lbs rider and 28h new Powertap G3 on a 38mm carbon clincher rim which lacing will be the best?
-2 times 2 cross
-2x NDS, radial DS
thanks!
mentok
by mentok
someone with more knowledge than me will hopefully chime in with specifics, but i believe there are manufacturer defined restrictions for lacing patterns and spoke counts on powertap hubs to ensure accuracy of power measurements. I don't recall what the restrictions are or what models they apply to, sorry.
perhaps the kids in the wheelbuilding thread could answer with specifics?
sawyer
by sawyer
mentok is right - there is a 2x min spoking for G3s
I actually recently had built:
- 38mm tub carbon rim
- P'tap G3, 24h rear
- 2x NDS and 2x DS with DT Aerolite spokes
Wheel feels stiff enough. I would say similar to Boras - i.e. not super stiff but certainly good.
bobqzzi
by bobqzzi
As stated above, the powertap does require minimum of 2X on both sides.
fio
by fio
PowerTaps require a minimum of 2x. Radial lacing will void the warranty.
FYI I have both my G3 wheelsets built with 24 spokes and 2x on ENVE 45 and H Plus Son Archetype. The G3 builds a great wheel, much better than the previous generations. I can definitely tell the difference between the G3 and my old PT Pro wheels in terms of stiffness. Have fun with the build :wink:
WMW
by WMW
It's funny how misinformation gets propagated. Many years ago Saris had a requirement for... actually 3x both sides... but it has been 2x on the NDS only for awhile now.
Per the G3 manual: "IMPORTANT: For your safety, the non-drive side of the PowerTap hub must be built with at least a 2x lacing pattern. Because of the patented PowerTap design, torque is
transferred through the hub to the non-drive side. Failure to adhere to this precaution will void the warranty."
But I'd never lace the DS radial. *If* you have derailleur clearance, you could lace the DS 1x heads-in. If not, best do 2x both sides. Using lighter NDS spokes will reduce the chance of them going slack.
formerly rruff...
NovemberDave
by NovemberDave
The latest specs on the website say "Hub must be laced with mimimun(sic) 2X pattern." I take that to mean both sides.
http://www.cycleops.com/en/products/power-meters/hubs/powertap-g3-hub.html?page=shop.product_details&flypage=flypage_images.tpl&product_id=542&category_id=20
The previous gen ones could be laced radial on the DS. I don't prefer doing that in any case.
deluxerider
by deluxerider
My 2x wheels are my favorites. 28 holes and bomb proof.
iboc23
by iboc23
Thanks for all your answer!
Still an other question about spokes:
Same kind of spokes on both side?
Or
Different quality on NDS?
sawyer
by sawyer
I went DT Aerolite all round. Because I've had good experiences with them, they are high-end, bladed, and matched the front wheel.
