drill holes in frame!
bugmenot
by bugmenot
Tomorrow I'm going to start drilling holes in my old cromoly commuter frame to get the weight down. Don't worry, I have a helmet. Will let you know how it goes!
Washdogg
by Washdogg
Surely this will only end in a flobbely frame? I guess if you drill holes at 45 degrees to vertical/horizontal you will retain the most stiffness... Good luck - will be interesting to see how you get on!
dmp
by dmp
bugmenot wrote:... Don't worry, I have a helmet.
With ideas like this you probably don't need one...
HammerTime2
by HammerTime2
I might suggest also drilling holes in your water bottles. It turns out, most of the weight savings is not from the bottle per se, rather from the reduced weight of the water they carry.
MortenE
by MortenE
Wow! Why haven't I thought of that before! I lost almost a kilo!
bm0p700f
by bm0p700f
There is a good reason why steel frames do not come with lots of holes drilled in them and why 953 and XCR tubing is now drawn. A very good reason indeed.
HammerTime2
by HammerTime2
bugmenot, are you a slightly less insane reincarnation of HanSolo?
In Drilling holes in CF frames to save weight, HanSolo wrote:Hi,
I am interested in drilling holes through the seat tube of my Kestrel Evoke to save weight. It looks like a sturdy bike and I feel that the seat tube is not very structural....any thought? How about the top tube?
Everything can be drilled, except tires.
austke
by austke
Lmao, " Everything can be drilled, except your tyres".
On a more serious note, some things are more suited to tuning than others.
Frame and fork failure are more dangerous than say front or rear mech. Bugemon? Take care which ever way you go.
2013 Giant TCR Advanced SL 0, 6.92kg
2013 Giant Defy Composite 2 M, 8.5kg - Wife's
Azzurro Torino 8.55g
Fuji 650 10.8kg
Miele Lupa Triple Tandem 38,89kg
asphaltdude
by asphaltdude
Don't drill, shave!
Whow! That's a pretty damn nice garage door!
crohnsy
by crohnsy
Where's that dude with the Swiss cheese seatpost when you need him???
Phill P
by Phill P
Bah back in the 70s and 80s track riders used to drill out their frames all the time. Yes they lost stiffness but if you get your power from doing 150rpm you wanted to accellerate up to full power as quickly as possible.
Sure there are better places to drill on the frame than others, but if it is a strong frame drilling holes in the middle sections of the tube and leaving plenty of material between each one won't be so bad. Just don't drill 100 holes in your first attempt. See how the frame feels before drilling more (and more).
Also file the holes so there are no rough edges to act as crack propagation points.
Technical Director at www.TUFFcycle.com
Wingnut
by Wingnut
"It's not the destination...it's the ride!"
Eros
by Eros
Drilled chainstays do actually look quite good.
HammerTime2
by HammerTime2
until they break.
xnavalav8r
by xnavalav8r
Yeah, but those chainstays actually have tubing brazed into them perpendicularly. Those holes are for looks, not weight savings. In fact, the material added probably weighs twice what was removed.
