6Kg 2013 BMC SLR01 (Retired)
engi
by engi
That's some serious weight savings on tires alone! What size were the Contis and what size are the Veloflex?
CAMSHAFT
by CAMSHAFT
engi wrote:That's some serious weight savings on tires alone! What size were the Contis and what size are the Veloflex?
Both 23 I believe....
Sent from my iPhone using Tapatalk 2
Fanis
by Fanis
Nice built!!!
What do you think about veloflex vs 4000s???
Storck Scenario C 0.9
Cube AMS Pro 125
CAMSHAFT
by CAMSHAFT
Fanis wrote:Nice built!!!
Thank you!
I haven't taken them out yet... Ill let you know tomorrow.
caballero
by caballero
The slam that stem headset cover was a direct fit with the included fsa headset ? We're any micro spacers needed for correct height ?
Want to use one on my rm01
CAMSHAFT
by CAMSHAFT
caballero wrote:The slam that stem headset cover was a direct fit with the included fsa headset ? We're any micro spacers needed for correct height ?
Yes but not perfectly. There's a slight vertical gap and some diametral overlap... I didn't use any spacers below or above the headset cover. If you PM me a reminder ill take a close up pic for you.
caballero
by caballero
Cool, pm sent !!
CAMSHAFT
by CAMSHAFT
Cables and Veloflex done... Weights and pics tomorrow!
CAMSHAFT
by CAMSHAFT
I ran into a snag.... I added weight via a cassette spacer, and some chain links needed. Then they weren't able to fully complete the rear brake installation and have to order the parts for it. With the above added, Veloflex swapped, and the three cables done I added two ounces
And the rear shifting isn't dialed in 100%. :(
BmanX
by BmanX
If the Conti are 4000s with Chili I would put them back on and have the better rolling resistance. Weight is not the only thing you need to work about. The Conti's with latex will roll better. Look at the whole picture which I think you are almost doing. You have aero and weight but don't forget rolling resistance. Also the Conti's normally have better flat protection which gets you to the end with less issues.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
CAMSHAFT
by CAMSHAFT
BmanX wrote:If the Conti are 4000s with Chili I would put them back on and have the better rolling resistance. Weight is not the only thing you need to work about. The Conti's with latex will roll better. Look at the whole picture which I think you are almost doing. You have aero and weight but don't forget rolling resistance. Also the Conti's normally have better flat protection which gets you to the end with less issues.
They are with Black chili... Well see how the Veloflex perform tomorrow. I read from multiple people they are a close to tubular feel.
CAMSHAFT
by CAMSHAFT
Yep it's time for an update... More this week!
CAMSHAFT
by CAMSHAFT
So with the rear brake taken care of I am back to 6.18 kg... Here's how she looks from the front. Closeups soon.
CAMSHAFT
by CAMSHAFT
I couldn't stand the Veloflex Corsa, so I am trying Zipp Tangente. I added 140 grams in the name of comfort. I did 50 Saturday and the Tangente are miles better; road feel, compliance, and cornering each eclipse the Corsas'! New weight and AICAN pics soon!
CAMSHAFT
by CAMSHAFT
Trying out Conti Race Supersonic... 40 gram savings... :D
