veloplugs with boyd wheels?
Bianchi10
by Bianchi10
Anyone happen to know if veloplugs (red or yellow) will fit a set of Boyd Vitesse 30mm aluminum clnchers?
mnmasotto
by mnmasotto
Call Boyd on the phone and ask them the diameter of the spoke holes. The veloplugs come in two sizes red and yellow. I am sure the guys at Boyd will know which size to order.
btompkins0112
by btompkins0112
Aren't those just XR300's?
If they are, I think they take the yellow ones.
EDIT: if they are XR300's they are the red ones.
fdegrove
Tubbie Guru
by fdegrove
Hi,
From memory, the yellow ones are 8mm while the red ones are a tad bit wider coming in at 8,3 mm if that helps.
If you don't want to contact the manufacturer just use a calliper and measure the diameter of the holes.
Ciao, ;)
robertg
by robertg
fdegrove, it is actually the opposite, as the red ones are smaller than the yellows.
