Is carbon flammable? Only one way to find out...
elviento
by elviento
Some guys in a local cycling group asked this question recently and frankly I don't have an answer. Someone did say resin has a 200-degree ignition temp and fibers have a 600-degree ignition temp.
Since we happen to have a frame from the fatigue test, we are going to try to burn it and see what happens. And also throw in some beer and roast wings and sausages.
You know, to keep it recreational as well as educational.
Stay tuned.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
www.falcobike.com
Facebook: falcobikeglobal
michel2
Location: somewere floating between here and the other side
by michel2
I put a six pack on saying it has trouble burning. From reading all the marketing, a good carbon fiber tube should not contain any oxygen ? I think you would to put in a fair bitt of effort to get it started !(;
Schleckond
by Schleckond
Carbon doesn't burn (there is nothing to burn) but the resin will burn away and you will be left with (basically) the bare fibres/fabric left. The fabric won't stay together though as the binders will have burnt away.
prendrefeu
by prendrefeu
You might want to wear a mask anywhere near the burn, make sure it has filters for organic vapours. Basically, don't get cancer.
The resin might not 'burn' like a normal fire, but it may alite and carry a semi-visible flame. You'll certainly smell it. Which is bad.
The carbon won't burn though.
NiFTY
by NiFTY
Yeah i saw one guy do down in a crit. Fireball.
prendrefeu
by prendrefeu
Also, a quick search on the internet can pull up what I'm referencing: http://www.aviationfirejournal.com/avia ... azards.pdf" onclick="window.open(this.href);return false;
Basically, stay the f*ck away from that burn. Don't eat anything you're putting on that fire. Hell, don't even be anywhere near it. Save your life.
How do I know this sht? I worked in a rapid prototyping lab for a few years (part-time). We had laser cutters among the many tools there... and that's a great way to know what the hazards are in burning various materials, even if it is just a laser cut.
Wingnut
by Wingnut
I've seen a few carbon surfboards and a paddle board melt due to the way black carbon absorbs heat/sun so readily...
"It's not the destination...it's the ride!"
HillRPete
by HillRPete
elviento wrote:Some guys in a local cycling group asked this question recently and frankly I don't have an answer. Someone did say resin has a 200-degree ignition temp and fibers have a 600-degree ignition temp.
For the resin, well, it depends on the resin. I'm fairly sure having seen Zipp say they are testing their brake tracks at over 200 degrees. (Kelvin or Celsius, that is the question though).
The carbon fiber itself will take more than 600. Formular 1 brake rotors go into the 4-digit in operation. Probably depends on the type of fiber too.
In any case the resin's and carbon's respective spec sheets would have the details, I suppose.
Schleckond wrote:Carbon doesn't burn (there is nothing to burn)
Well, what about the carbon? :mrgreen:
elviento
by elviento
Thanks for the input above. It would certainly be nice to have first hand experience with the result, since I have been asked many times what sunlight or a house fire could do to a carbon frame.
BTW, if it doesnt' burn, we will use the frame as a BBQ rack (just kiddin' Prend:-)).
www.falcobike.com
dcl10
by dcl10
It depends on the type of carbon as well. Prepreg layups will typically have a lower melting point and may become soft and pliable before combustion occurs.
madmole
by madmole
Carbon is what you get left after a fire.
Cervelo S3 2011. Blinged 6.718 Kg
sungod
by sungod
carbon burns, producing carbon dioxide and/or carbon monoxide
C + O2 → CO2
2C + O2 → 2CO
an everyday example is bbq charcoal, i.e. lumps of carbon, it burns
Copperband
by Copperband
Hi Elviento,
I came across this blog post some time ago and I think it should answer your question.
This titanium Seven Aerios frame was caught in a house fire and the carbon seatpost which was on the frame just exploded. It didn't burn.
Some pictures of of the titanium frame after the fire.
The picture of the carbon fibre seatpost.
Source: http://cozybeehive.blogspot.sg/2009/03/can-titanium-frame-be-reused-after-fire.html
HillRPete
by HillRPete
elviento, you got me interested.
Flammability Properties of Aircraft Carbon-Fiber Structural Composite http://www.fire.tc.faa.gov/pdf/07-57.pdf
artray
by artray
Carbon is horrible stuff to mess with . Just cutting or tuning bits, the dust is really awful .
Why on earth would you want to burn it . Seems like a stupid thing to do and maybe a health risk .
