Internal routing outer cable Campagnolo 11s
chickenbourne
by chickenbourne
Refreshing my cables (both inners and outers) on my EMX-7 and wondered if anyone has any experience with Campag 11 speed and internally routed brake and gear outers? It seems that the Campagnolo kits don't have enough outer to even think about internal routing... Any advice/workarounds appreciated and white or red outer suggestions please :D
bontie
by bontie
You don't route the casings through the frame, but use whatever cable stops go with the frame.
Casigns should match the frame and in 99% of cases balck is best/safets - YMMV
chickenbourne
by chickenbourne
Oh I see. I thought the outer went the entire length as when I pulled on the rear brake cable outer from the stem end (routed through TT) it pulled the outer from the brake end suggesting a continuous run of outer....
Okay white outers then please
fdegrove
Tubbie Guru
by fdegrove
Hi,
On some frames you're supposed to run the outer (brake) casing through the frame. These frames do not have stops at the cable outlets so if you want to run the inner cable inside of it you'll need to use stepped cable stops to keep the casing from sliding into the frame .
Ciao, ;)
thisisatest
by thisisatest
For brakes, a campy cable kit should have plenty. for the rare frame that sets their derailleurs like that, you're out of luck.
chickenbourne
by chickenbourne
I guess the easiest way to check is to undo rear mech cable to give me some slack and see what happens when I tug on the outer. If it moves at the bars I'm out of luck, if it stays where it is happy days! Thanks for the advice guys. Great service as always. :D
ultimobici
by ultimobici
Pretty sure the EMX-7 is the same as the EMX-5 in that the gear & brake casings go through the frame all the way. The stops are at the bottom of the down tube in the case of the gears, from memory.
bontie
by bontie
:oops:
I just thought it sounds odd that you'd need that much casing - this is WW after all
