Rotor Power Crankset with Sram Yaw Chainrings?
trtimothy
by trtimothy
Hi,
Any advice would be appreciated. Basically I want to use a Rotor Power 3d+ Crankset (with the Micro Adjust Spider) and the new SRAM Red Yaw Chainrings.
From what I understand I would need the SRAM Red non-hidden bolt chainrings as these just work with 5 bolt cranksets (not the new exogram one).
If anyone could tell me if this is possible I would greatly appreciate it, I can't find any info on using non-Rotor chainrings on their Micro Adjust Spider setup.
Thanks
petromyzon
by petromyzon
I'm afraid I can't answer your question but have you actually got a Rotor Power yet? If so - photos pls:)
trtimothy
by trtimothy
Not yet, was just about to order one. (They're out in February). They have the same chainring mount as the rotor flow though if that helps anyone.
upside
by upside
You shouldn't have an issue.. it's just another front derailleur.
trtimothy
by trtimothy
Sorry if I wasn't clear...question is can SRAM yaw chainrings be fitted to a Rotor power crankset with the micro-adjust spider.
Not if a sram derailleur will work with rotor chainrings.
upside
by upside
Boy, I would give Rotor a call. They are pretty good with customer service and have a lot of qualified guy's on hand to answer any question.
boots2000
by boots2000
Just get Praxis rings and call it good.
refthimos
by refthimos
upside wrote:Boy, I would give Rotor a call. They are pretty good with customer service and have a lot of qualified guy's on hand to answer any question.
This. I have ordered 4 different sets up Q-Rings from Rotor USA over the phone and they always seem to pick up the phone before the phone has rang twice. They are in Boulder so no worries about any language barriers. Give them a call.
EVO Hi-Mod | 9070 Di2 | Rotor 2Inpower | Aeolus TLR 3/5
P5 | 9070 Di2 | Rotor 2Inpower | Aeolus TLR 7
T1 | Power2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
SuperX Hi-Mod Disc | Sram Red | Power2Max NG
