HP minipumps: lezyne , topeak or...
quattrings
by quattrings
Topeak racerocket hp
Lezyne HP drive
Which one is to best?
If I flat a tubular can either one reach 8 bars/115psi realistically without gorilla strength?
Thanks
5 8 5
by 5 8 5
Not quite what you're asking but I tested a Topeak Race Rocket against a Lezyne HP Road Drive (M 160psi).
I found the Topeak was a bit faster to 85-90psi but then it struggled. The Lezyne got to 120psi without any problem.
I didn't find the Topeak that comfortable to use. It was easy to nip my non-pumping hand when using it.
For 115 you're better off with Road Drive.
bikerjulio
by bikerjulio
Lezyne
There's sometimes a buggy.
One.
project3
by project3
Lezyne
personally i own two unit. tried topeak - material feels low quality after i tried using my ride buddy topeak. feels fragile.
Ozrider
by Ozrider
+1 on the Lezyne. My Carbon Drive is the best mini pump I have ever owned, and is lighter than a CO2 canister and chuck.
Ozrider - Western Australia
eric01
by eric01
Lezyne. Its a little pricier. But when you pick it up and use it, you feel like "oh, I get it".
AX Lightness Vial Evo, Carl Strong Titanium
sungod
by sungod
^^^ this, this, this, this and this
quattrings
by quattrings
Lezyne it is, and it is actually cheaper.
thanks to all and happy holidays.
Franklin
by Franklin
The best is the Quicker pro, it's a better pump than either Lezyne or Topeak bring to the table. And it fits in a shirt pocket!
1415chris
by 1415chris
In what respect, best?
Pump without the hose, it's not the best idea. And it's twice heavier than Lezyne.
quattrings
by quattrings
1415chris wrote:In what respect, best?
Agreed. Forgot to mention but it has to be a pump with a hose.
If you only ride with one spare tube (and a patch for security), you really don't want to blow (pun intended) that one shot.
Franklin
by Franklin
It's absolutely the best pressure wise. You can get decent pressure whith a lot less effort than Lezyne.Test
And it might be heavier, it's really compact.
1415chris
by 1415chris
But the same time your presta valve can be easily smashed. It happened twice to me, using this kind of pumps.
Since then, only hose pumps for me.
Franklin
by Franklin
1415chris wrote:But the same time your presta valve can be easily smashed. It happened twice to me, using this kind of pumps.
Obviously it's where your preference lies. Considering I have been standing on the side of the road in the cold rain with a Lezyne which couldn't get the necessary pressure I got rid of it fast. *
I rather take care with the valve and use a pump that actually works. lezyne really let me down in that respect .
And not just me!
On the Quickex you will find some slamming the gauge meter and the paint falling off... but it's absolutely praised for getting the job done at reasonable exertion.
Another problem with some Lezyne hoses: The rubber seal goes bad after just a few uses and the hose won't stay on the valve. The lack of a clamping mechanism is problematic, especially if you will only find out when you stand beside the road.
1415chris
by 1415chris
Not sure to which Lezyne models you are referring to, but I though all of them come with threaded hose ends which are screwed on the valve. It's hard to imagine more robust solution, isn't.
I'm in possession of 2 Lezyne pumps, CNC floor and Road Drive and I can only speak in superlatives about them.
On the other note, for some members of this forum (myself included) it would be very hard to justify twice more weight, in the situation when this twice lighter pump does the job properly even if slightly more effort is required.
But agree with you on the individual preferences.
