Show me Your Tuning!
Marin
by Marin
Don't touch the carbon.
111OCT111
by 111OCT111
Bridgeman wrote:
Fri Jul 06, 2018 12:34 am
To the above post; I broke a collar bone as a result of a crankset failure.
Sorry to hear that.
weeracerweenie wrote:
Fri Jul 06, 2018 2:10 am
Re: Modifying Carbon cranks, id never touch them in anyway other than stripping paint. I’ve snapped in modified crank arms and got lucky not hurting myself. No reason to increase the risk. Save some $$ and get some better cranks.
Yeah, I have exograms on my main bike. I was hoping to hear more from users who successfuly experimented with those cranks.
Marin wrote:
Fri Jul 06, 2018 7:52 am
I won't.
andreszucs
by andreszucs
Scotch shipping strapping tape, 5.4g on a 26” wheel. Image
weeracerweenie
by weeracerweenie
andreszucs wrote:Scotch shipping strapping tape, 5.4g on a 26” wheel. Image
Any idea what the stock / old stuff was and weighed? That’s strong tape too
I guess there's worse hobbies than making a bike light? Right?
andreszucs
by andreszucs
Not exactly, but Looking on my old notes Notubes tape should be around 8-10g for the same wheel size, gorilla tape double from that at almost 20g.
Klaster_1
by Klaster_1
Did you break your Clavicula, clavicula or both?
andreszucs wrote:
Thu Sep 06, 2018 5:00 am
What's the rim/tape width? Tesa 4289 in ~20mm is about ~5.5g for one layer on 700c rims. Did you tubeless it too?
kode54
by kode54
no blow through on spoke holes?
that's what i'm always afraid of. looks like only one wrap revolution...not twice?
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Chebacco + DA9170 + Enve G23 CK CL hubs
- Allied Able + DA9170 + Enve G27 CK CL hubs
andreszucs
by andreszucs
kode54 wrote:no blow through on spoke holes?
I rocked 40 psi in it with a 2.1 tire and it was just fine, yes, just one revolution.
WILLIAMDENYS
by WILLIAMDENYS
someone has tips on what parts are easy to tune? dont have to much experience with tuning myself.
- ridley fenix sl 105 - not lightweight
- sworks tarmac sl 5 r8050 di2 - vision tc 24 wheels = 7,1kg
Marin
by Marin
Everything you can take a drill to basically :)
4ibanez
by 4ibanez
I'd suggest non-loading-bearing parts ;)
euph
by euph
After the previous posts discussing cutting holes in carbon cranks I wouldn't agree with Marin's post. If it is made of metal then you can take material out. But carbon is much more susceptible to stress risers etc. when you remove material.
Non load bearing parts/non safety critical parts is a good place to start though.
WILLIAMDENYS
by WILLIAMDENYS
Tried my first time modifying something myself (just a test so not very properly done) made some brake shoes bit lighter... doesnt look very nice but saved the weight... this was an old set of brake shoes so will be doing this more nicely with better shoesImageImageImage
Verzonden vanaf mijn iPhone met Tapatalk
TheKaiser
by TheKaiser
WILLIAMDENYS wrote:
Mon Nov 19, 2018 7:50 pm
Looks pretty decent. Out of curiosity, have you mounted them on the bike and given them a squeeze yet? Curious if the rubber pad material has a tendency to bulge out in that larger cutout opposite the pad retention screw.
WILLIAMDENYS
by WILLIAMDENYS
No... just did this today and have to test it. I think the pad will not be very stuck in it because the lips are really not thick...
