AX Lightness Orion pad holder nut size?
jz4nyc
by jz4nyc
Subject header says it all.
Need to know size and thread pitch of the pad holder nuts.
Thanks!
jz4nyc
by jz4nyc
anyone? m5? m6?
jz4nyc
by jz4nyc
:noidea: does anybody have these brakes?
help!
(actually, i'm trying to help a pal out who has 'em but isn't too savvy on how they're designed/made, and i don't have ready access to the bike otherwise i'd be answerin' my own questions... :wink: )
hard to tell from photos if the bolt is molded into the pad holder itself and a nut screws on top of it outside the caliper, or if the pad holder itself is threaded and a regular m5 bolt screws into it (like most brakes, a la shimano, et al).
artray
by artray
They use M5 bolts :thumbup:
jz4nyc
by jz4nyc
you mean bolt screws into pad holder? happen to know how long the bolt is? an m5x5 or maybe 10?
thanks!
YinYang
by YinYang
+M5 bolts; don't know the lenght but bottle cage bolts will works.
jz4nyc
by jz4nyc
perfect, thank you. those are m5x5 if i recall.
what would you recommend, ti or aluminum?
want to get 'em in black anodized. dunno if i can find black anodized ti.
YinYang
by YinYang
I would go with titanium. The original bolts supplied by AX are aluminum which I ripped off the heads by simply hand tighten like your friend.
Bottle cage bolts comes in various lengths, make sure you get the correct length cause too long of a boltswill push the pad out of the holder.
jz4nyc
by jz4nyc
yin yang, thanks a ton.
artray
by artray
I use some Ti bolts that I painted black .
fdegrove
Tubbie Guru
by fdegrove
Hi,
The bolts are marked 4Nm so they must be made of aluminium. Probably 7075 T6 spec. They require a Torx T20 key to tighten too.
http://r2-bike.com/AX-Lightness-Bremsschuhe-Carbon
http://r2-bike.com/Trickstuff-ubs-bremsscheibenschrauben-aluminium
Ciao, ;)
jz4nyc
by jz4nyc
fdegrove--wow, that site is the mother lode of ax lightness stuff. i forgot they made frames too. very fancy!
and thanks to everyone for your help.
jz4nyc
by jz4nyc
FYI, AX Lightness informed me the bolt is M5x12.
