Light 27.2 seat post options?
PhilThee
by PhilThee
I need a setback carbon 27.2 seatpost.
I currently have the Aluminum Bontrager Race light with a 5mm setback.
I used this post partly because the angle adjustment is infinite and I'd like to keep with that. I don't care for the graphics on the Bonty XXX Lite though.
The seat is slid as far back as the post will allow. It works but it's heavy and I don't like the seat rails being slid all the way back. I'd like to get a little more setback and lighten it up a bit.
I know there are some great posts out there but I can't spend 225.+ on a seatpost.
What are some lighter options in those parameters?
I'm thinking Ritchey Carbon 1 bolt???
** WANTED BLACK Cannondale Full Carbon forks.Please PM me with what you have. I need a 8.5+inch steerer tube length.
GrahamB
by GrahamB
I have the Dedaccai (?) Black Stick. I think it's about 165g at 300mm. The only downside is the finite-step angle adjustment. That turned out ok for me, but if you are super fussy about your seat angle you may not like it.
Graham
PhilThee
by PhilThee
GrahamB wrote:The only downside is the finite-step angle adjustment. That turned out ok for me, but if you are super fussy about your seat angle you may not like it.
That I am. That's part of the reason I was using the Bontrager. Infinite angle adjustment.
I was considering the Bonty XXX Lite but I just don't care for the graphics on it.
Mike V
by Mike V
The Ritchey two bolt is lighter!
Juanmoretime
Administrator
by Juanmoretime
Alpha Q Prolite is my favorite. Carbon with 20mm of setback and a two bolt system that allows plenty of fine tuned adjustment. My 31.6 X 350 is 193 grams and my 27.2 X 350 is 181 grams.
http://www.alphaqfork.com/performance_tubing/posts.asp
RESIDENT GRUMPY OLD MAN.
PhilThee
by PhilThee
Mike V wrote:The Ritchey two bolt is lighter!
Is that so??
How is it for adjustably?
Does it have any notches in it that will lock the seat at a predetermined angles?
Johnny Rad
by Johnny Rad
Easton EC90 post. Set and forget.
Trim it to length to reduce weight. Also, search for a thread on lightening the clamp.
I previously tried a M2Racer seatpost and the adjustment was finicky and creaky. So so very light, but I gave up before I got it dialed in.
Mike V
by Mike V
Is that so??
Yes
Good
No
PhilThee
by PhilThee
Not sure about the Easton.
urace4me2 wrote:My easton EC90 keeps slipping to backwards tilt every time I do a race where I climb hard. As far as I'm concerned it's a POS for anyone with any weight above 150 lbs. But I still have it on my race bike and will just retension it carefully before each really hilly race.
The reply
DocRay wrote:^^ try assembly paste on the semi-round to avoid slipping, but I've heard of this problem from many.
JBuck
by JBuck
Im using the Forte carbon post from Performance bikes.
160 grams and only $75.
Rascal
by Rascal
PhilThee wrote:
Is that so??
Yes
Good
No
As I recall, the Ritchey two bolt does have notches at the interface of the individual bottom nuts and the carbon curved piece that they mate to, causing it to be, in effect, not totally infinite but rather has predetermined angle settings. This is for the most recent Ritchey carbon two bolt.
-Giant TCR
-CAAD5
-Klein Rascal
PhilThee
by PhilThee
Rascal wrote:As I recall, the Ritchey two bolt does have notches at the interface of the individual bottom nuts and the carbon curved piece that they mate to, causing it to be, in effect, not totally infinite but rather has predetermined angle settings. This is for the most recent Ritchey carbon two bolt.
That's no good.
PhilThee
by PhilThee
How about the FSA K force Carbon?
Scratch that. I just saw some pictures of the clamp. It has notches.
5 8 5
by 5 8 5
PhilThee wrote:Not sure about the Easton.
Notched adjustment on the setback version.
PhilThee
by PhilThee
So far it's
Alpha Q Prolite
Ritchey 1 Bolt
Bontrager XXX
