BB30 Chainset weights
stevenb
by stevenb
Looking for a new BB30 chainset and wanting to know if when they give weights it includes the bottom bracket.
eg SRAM Force says 645g w/bb. Does the 'w' mean with or without?
FSA SL-K Carbon chainset website shows figures under 'Crankweight' which I'm guessing excludes the bottom bracket element especially as it's under the 600g mark.
Cheers
Steve
Planet X RT-57 custom build ongoing....
rijndael
by rijndael
stevenb wrote:Does the 'w' mean with or without?
w = with
w/o = without
Estelja
by Estelja
Most BB30 stated crank weights will be without BB. The BB is only two 6806 size bearings, circlips, a couple of dust caps and some shims. A typical BB30 BB will weigh 65-70 grams and are sold separately from the cranks.
stevenb
by stevenb
Estelja wrote:Most BB30 stated crank weights will be without BB. The BB is only two 6806 size bearings, circlips, a couple of dust caps and some shims. A typical BB30 BB will weigh 65-70 grams and are sold separately from the cranks.
Thanks for that.
So if I have an existing FSA Gossamer Pro BB30 chainset and upgrade to a SRAM Force or FSA SL-K Carbon I can simply retain the existing BB bearings in the frame or do I have to buy SRAM/FSA specific bearings?
First BB30 bike I've had you see.
Cheers for your help guys.
Anders
by Anders
Depends on if the spacers/dust caps comes with the crankset or the BB. They might also be integrated into the crankarms, I know they are on some FSA cranksets. Yes you can use the same bearings.
