1998 Trek 5220, stripped 6.41kg, fork changed
djay001
by djay001
Hi there,
i'm on this forum for about half a year, the most part of my post for now are on the road wheelbuilding subject.
I just want to introduce you my little bike... This is a 1998 trek 5220, yes 5220 lol, this was made one year only supposed to have a triple ultegra group but mine was with 105 triple group.. supposed to get the name of trek 5020.. something is missing here i think.
I will not try to hide you that my project was inspired by the beautiful nude carbon trek i have see here.
So, The first pic is the bike when a bought it, when i see it like that i'm questionning me about why i bring it home, it was not really hot.
After a year a put my hand on a bike with the component of the trek 5200 from year 2001, and i swap the parts(the rolf wheel and ultegra triple group).
And now i have changed about everything on the bike, with a 10 speed groupset. I also strip the paint of with the razor blade technique and a light wetsanding, i also did it on the bottle cage, the crank and the seapost. I have applied the clear myself, it turn out good but not perfect.
Crankset: FSA K-Force Light compact (decal removed and new clearcoat) 579gr
BB: FSA BB-8681 100gr
pedal: exustar carbon and titanium 185 gr
Shifter: Sram Red lever
Rear derailleur: Sram Red (with rival tuned outer cage) 157gr
Front derailleur: Sram Red black 70 gr
Chain: Yaban chain
Brakeset: TRP 920 brake
Cassette: Sram red 11/26
Handlebar: 3TTT prima 199
Stem: Ritchey WCS 1 1/8 to 26mm 110mm. 110gr
Headset: Cane Creek 40 headset
Seapost: Forte Precision (cut)
Saddle: selle italia SLR stripe off
Wheelset: wh-7850-c24 tu 1250gr
Tire: wittoria evo CX tubular 250gr
Fork: Bianchi full carbon 1inch 325gr
Frame: 1998 Trek 5200
the weight when i got it was over 21 pounds and now i get 6.41kg or 14.15 livres
now the pic!
The present bike (update 2015_04)
at beginning
after the upgrade ultegra and rolf wheel
the process of removing the paint
The final build
The new wheelset
I'm checking for some TREK decal for the bike, and maybe in the futur to change the headset for treadless and the fork/steam, here i could get about 300gr easily
artray
by artray
Another one :thumbup: Everyones at it, great stuff . I got my decals for my Trek from a sight on ebay.
Nice job .I think the stem change would look better as well .
:beerchug:
djay001
by djay001
i just find some weight picture
the frame is with the clear coat on, but witout bolt and cable ajuster
this is a precision (performance bike brand) forte 27.2mm 300mm long
the k-force light compact crank without logo and new clear
the original 1998 fork 1 inch with cromoly treaded steerer stripped and new clear
rival rear derailleur
trek braze on adaptor, in heavy steel,
trp 920 sl brakes
yaban chain
SWijland
by SWijland
Very nice! And that frame weight is much lower than I would have thought!
djay001
by djay001
yes the frame is light and i was really impressed by the weight of the original fork.
without clear coat it was about 425g, before removing it from the frame i was thinking that the fork weight was about 500 or 600g, because i have seed a lot of entre level treadless fork with aluminium steerer at that weight.
lo5707
by lo5707
Nice job :thumbup:
The clear coat looks great from the pics. Do you know how much weight you saved by removing the paint job - i.e. what was the frame weight before compared to the 1041g final weight?
djconnel
by djconnel
Incredible!
djay001
by djay001
lo5707 wrote:Nice job :thumbup:
I don't have the exact weight with the old paint. I have just weighted it with the little part like the cable guide, head-set, etc.
I was too happy to began the stripping that i have not take the time to unscrewed everything and weight up the frame.
But with what i have seed when i weighted it, i guess i save aroung 50g.
djay001
by djay001
new picture with my 1390 g wheelset and slr stripped saddle, 38gr skewer, sram red cassette
like that it weight 7.02kg or 15.48 livres
dolophonic
by dolophonic
Good job..! looks way better. Yes maybe new stem?
Reamens
by Reamens
Very good work.
I would suggest to make a normal steering headset and fork with a carbon fiber tube. It really is improving and could save a considerable amount in grams.
With the development of good luck!
djay001
by djay001
so i just get some decals for the bike, and a new sram red black front derailleur
i also got a new treadless fork, now i just need a headset and a stem. I think i will change the fork after this summer.
this fork is 350gr, with the top cap and the expander! The only bad side of this one is the color of the bianchi logo, and this stichers is under the clearcoat.
JDLBB
by JDLBB
Just sand it down and then clear coat it. Thats what I did. I put a cannondale fork on my Trek rebuild. Image
Burgunder
by Burgunder
With the new fork, a new headset and stem you might be right at the UCI weight limit!
