Light Intergrated carbon bar stem?
CBRE
by CBRE
Does anyone actually make a light reliable intergrated carbon bar/stem? Would like one in 100-110mm 42mm wide at 275g or less. My bar stem now is 165g Zipp SL bar and New Ultimate stem at 105g for 270 total. I like the aero advantage of the intergrated and possible(should be anyway) stiffness gain.
Curt Brown
2016 Cannondale EVO Etap 13.8#'s
2012 Cannondale Supersix EVO etap 13.7#'s
2017 Cannondale SUPER X Force 16.0#'s
2016 Cannondale FatCad2 28.1#'s
2011 Cannondale Carbon Flash 1 17.9#'s
gilesharrison
by gilesharrison
I don't think there's anything that light without looking at a custom bonded stem.
Most of the integrated bars/ stems are 350g or more. I have a Cinelli Ram 2 which is beautiful, super stiff and comfortable but weighs about 460g.
fdegrove
Tubbie Guru
by fdegrove
Hi,
Surely, in the grand scheme of things, this alleged aero advantage is totally insignificant?
I ride an integrated stem/hb BTW (Kuota Viking) which is not exactly light yet it's incredibly stiff. Remember also that these integrated combos do not allow for much tweaking of your position except for the height of the shifters.
Ciao, ;)
CBRE
by CBRE
fdegrove wrote:Hi,
Ciao, ;)
Very true, I'm just looking for every little aero advantage now as its been the the biggest gain for me even over weight.
Curt Brown
oysters
by oysters
Calfee do them custom. You can supply whatever stem and bar you like, I think, get it painted or leave it unpainted, etc, etc. Their website says a "typical" set up is 275-320grams...you might be able to go lighter with the right bar and stem combo.
fdegrove
Tubbie Guru
by fdegrove
Hi,
Fair enough but in that case a commercially available integrated bar and stem is not very likely to give you the same position as you have now. That is assuming you know this to be aerodynamically optimal.
Besides that, an integrated bar and stem isn't per defintion more aero than your typical stem and hb.
As oysters suggests above, the custom route seems to be the only logical answer. Whether that will end up as aero or lighter than what you have now remains to be seen.
It could be in theory but I have no idea whether or not a custom builder (Parlee or other) take the aero factor into account.
After all the total cx factor of rider and bike is not just the sum of all aero parts lumped together, it requires a far more holistic approach to yield a favourable endresult.
Ciao, ;)
BmanX
by BmanX
Get a Zipp Vuka Sprint bar and have someone bond on a stem. Would be around 300g and as aero as it gets. That is what I am doing.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
Mattias Hellöre
by Mattias Hellöre
AFAIK what I know so Signature, Berk and I can do custom if wanted.
Not sure if Berk do it, but he is a carbon cowboy.
Experimental Prototype
serbelo
by serbelo
A combo done by Madcow recently.226 grams
viewtopic.php?f=3&t=108043&p=924685#p924685
Cervelo R2.5
Cervelo P2c
Cervelo R3
Parlee Z3
Parlee TT
CBRE
by CBRE
serbelo wrote:A combo done by Madcow recently.226 grams
viewtopic.php?f=3&t=108043&p=924685#p924685" onclick="window.open(this.href);return false;
Wow now that is nice.
Curt Brown
fivethirtyonepm
by fivethirtyonepm
i've never weighed my cinelli ram 2, but i did weigh my GBP70 chinese takeaway jobby which came out at 388g for a 42 c-c and 110mm extension.
Mattias Hellöre
by Mattias Hellöre
217gr prior final sanding and clearcoat, note invisible clamp to steerertube.
