Deda's new stem and handlebar
corky
by corky
LionelB wrote:
OwenJames wrote:Nice to see there is a matching SuperLeggero seat post. Will be getting that for sure.
Anyone knows if any retailer carries this seatpost already ?
I can only find pictures on the Deda site so i assume it aint out there yet....
RMcC
by RMcC
I've got a 120mm stem and it weighs in at 125g.
Going to check my scales. Has anyone got a picture of the stem and bar together? I was going to change my bars to go with the stem but I've been put off by someone satin they don't match in a previous post.
RMcC
by RMcC
Must have got a heavy one. Gutted!
LionelB
by LionelB
my 120 is also 120g
HillRPete
by HillRPete
r_mutt wrote:
cerro wrote:dtddiver: Lovely bike, what bar is that? size? weight? An own thread?
Looks like a Deda Newton Deep.
Really? Isn't the Newton Deep way more rounded?
Kjetil
by Kjetil
Last time I saw the bike it was a Newton Deep all right. :)
Bianchi-Campagnolo
The Specialissima
GuyGadois
by GuyGadois
Those bars have an interesting shape on the top portion. Are those semi-flat? Looks almost square.
GG
HillRPete
by HillRPete
Kjetil: cool, thanks. Looks so rad on the De Rosa, with the drops tilted parallel to the top tube.
IhmeKameli
by IhmeKameli
Obviously many of you have installed these on your bikes.Could you please tell me safe torques (Nm) without slippage, when installing Superleggera bars to the Superleggero stem.
Only information i have found is on Deda website, first 5Nm then 8Nm.This is way too much, i think.
I do have a good torque wrench (Wera), and always use carbon paste for this kind of jobs.
Thanks in advance.
irongatsby
by irongatsby
After applying carbon paste, I'd start carefully making sure the gaps are even on both face plates top & bottom. I slowly tightened all 4 bolts to 4.5 newton meters. 4Nm may be enough. As you said, I wouldn't feel good about going over 5nm. Also, I wouldn't go past 7Nm to 8Nm on the shifter clamps. Campy says 10nm but I don't think that applies to these thin walled bars. Good luck.
dtddiver
by dtddiver
Yes, Deda Newton Deep. Love them.
Cerro, the bike has a 54 cm top tube and weighs about 6.8 kg with SR and the Boras.
borja
by borja
I have been talking with the deda engineer.. superlegera/superleggero is made to be good in stifness to weight ratio, however they are not engineered to be as stiff as Deda35.
I use 35 superleggera bar + 35 alloy stem 120mm and all together feels really stiff. The bar is very stiff on the top but not so on the drops.
mythical
by mythical
I'd like to see both Deda's Superleggero and Trentacinque stems in the results of the next batch of Fairwheel Bikes’ stem review.
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
carlislegeorge
by carlislegeorge
Just purchased matching set for a new build.
Stem in 110mm. This is the second of these stems I've bought, this one is 5 grams heavier in the same size then the first.
Bars in 44cm
2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
2012 Parlee Z5 SLi (just because)
2014 Colnago C59 (why not)
