DT Swiss 180 vs 190
LukasT
by LukasT
I'm planning to buy a racing wheelset and found a good price on a wheelset with stan's podium mmx, dt aerolite and dt hubs. With dt 190 hubs they are 649€ and with the 180 799€.
Is there any big differences between the 180 and the 190. Should I go with the 190 or is the 180 worth 150€ extra?
socratease
by socratease
Its not worth the difference, the 180s are just an updated version.
adama696
by adama696
Go for 240s!
I've got a pair of 190s and a pair of 240s. You have the "bling" factor but 240s are the same design and performance but half the price.
Cheers
LukasT
by LukasT
The difference in price between the 240s and the 190 is only 50€ and the 240s are ~100g heavier...
bikemaniack
by bikemaniack
190's are even lighter than the 180's.
Zen Cyclery
by Zen Cyclery
Dont go with the 180. It is the exact same as the 240 except for ceramics (which help with that placebo speed) and the carbon hubshell which only ends up saving you 8 or so grams.
I would say go with a 240. It is much more reasonably priced (all though I still think a bit expensive for what you get).
lowpsihighspeed
by lowpsihighspeed
Can't beat the whizzing sound of a 190!
Highline Outdoor Group | http://www.highlineoutdoor.com
sfer1
by sfer1
LukasT wrote:The difference in price between the 240s and the 190 is only 50€ and the 240s are ~100g heavier...
180s
Frong hub 107g (277.50 €)
Rear hub 207g (522,50 €)
Subtotal 314g
CL adapter 26g x 2 (included)
Total: 366g (800 €)
240s
Front hub 145g (175,50 €)
Rear hub 244g (237,50 €)
Subtotal 389g
12 titanium bolts 15g (25 €)
Total 404g (483 €)
800 € - 483 € = +317 €
366g - 404g = -38g
stephenjames
by stephenjames
The 180's are great but factoring in the CL adaptor as mentioned the difference is small. I went 180 for a dry wheelset and 240 for a wet weather wheelset - both have been faultless
mikhelee
by mikhelee
Yes, i know XX1-cranks are carbon (wrote about that in my last post). Just tried to list possible solutions/idéas with the Stages X9 left crank. I got the wild or stupid idéa to run a X9-crank on the left from Stages with the XX1-crank + spindle on the right. Will not look very nice though... :oops:
sfer1
by sfer1
mikhelee wrote:Yes, i know XX1-cranks are carbon (wrote about that in my last post). Just tried to list possible solutions/idéas with the Stages X9 left crank. I got the wild or stupid idéa to run a X9-crank on the left from Stages with the XX1-crank + spindle on the right. Will not look very nice though... :oops:
First, wrong topic.
Second, how could you have written about that in your last post if this was your first one?
bikemaniack
by bikemaniack
It was coppied from this thread
viewtopic.php?f=1&t=107137
Strenge things happened here:)
alicetaylor
by alicetaylor
I would like more information about this, because it is very nice., Thanks for sharing.
