Pressfit30 creak
logy
by logy
Arghh. Rode super six evo after washing and it creaks awfully. Have eliminated most obvious things such as qrs headset stem bolts pedals chainring bolts wheels shoes etc. are these bbs prone to wear or do the cranks need regular attention?
boots2000
by boots2000
Yes- especially prone to wear/creaking especially the PF30 and Hollowgram crank combo.
Reason: please don't quote when making a reply.
Zigmeister
by Zigmeister
Loctite 609. Done.
oreoboreo
by oreoboreo
+1
The solution for the BB90 creek also
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
logy
by logy
Re-install crank or ne bb? I can't believe this has worn after 6 months use!
clarkson
by clarkson
Probably not worn out, just need to reinstall with loctite as mentioned above.
Zigmeister
by Zigmeister
Exactly, getting the tolerances to such tight standards for the BB itself and the outer diameter of the bearings is difficult.
Surprised more pressfit, bb30 don't creak.
jasjas
by jasjas
Before you reinstall with loctite, perhaps take the crank out, clean, regrease and make certain the left hand crank bolt is torqued up correctly - 45 to 55nm i believe, this worked for my GFs Caad10 when it started creaking.
logy
by logy
Where expectantly should the Loctite or grease be applied?
logy
by logy
Regressing appears to have worked!
em3
by em3
repacking with grease is only a temporary fix...like others have posted above, use Loctite 609 and be done with it.EM3
______________
