Power2max bb30 crank (alternatives?)
tri
by tri
Hi,
I'm about to purchase a power2max power meter but I'm a little unsure over the selection regarding crank alternatives, solely which one will fit. My TT bike (planet x exocet 2 with press-fit bb30 bottom bracket.) currently has a Sram Force bb30 crankest. I'm thinking I want and can chose the Rotor 3D Plus, can I? Or which crank should I chose for my bike?
Please help me choose a crank that fits so I do not buy the wrong one that doesn't.
ChristianB
by ChristianB
Hi,
Write them a mail with specific question and all the technical data. They will get the right one for you.
csf
by csf
Rotor 3D+ will be right one in your case :beerchug: With SL4 works superb :thumbup:
tri
by tri
Great. I received the same answer from p2m themselves, answering mails on a Sunday morning? (me likes!)
roca rule
by roca rule
The older sram s9500 or s900 come in bb30 and are p2max compatible. If you are in Europe there is a borg crank (or something that sound similar)
Sent from my PG86100 using Tapatalk 2
dierix
by dierix
mine is a rotor 3d+ instead of the standard non power red crank i used before. works perfectly
Beancouter
by Beancouter
Roca rule I think you will find that that the p2m spider Is not compatible with the later bb30 900 series cranks. I emailed them and they told me the crank am needed to be customised.
