Athena 11 EPS
Tumppi
by Tumppi
Ok, here are the Athena EPS weights for weenies:
286g (+24g vs. super record EPS)
230g (+32g)
152g (+20g)
166g ( +/-0g)
+ interface 22g
EPS Athena is about 76g heavier than super record EPS and the cost for uppgrade kits about 1000€ vs. 2000€. :noidea:
Sorry for dirty (ski wax) table on background. :unbelievable:
wasabi1
by wasabi1
Seems a bit of a bargain. Weight v. Price.
Also the performance is very similar I believe.
istigatrice
by istigatrice
Interesting, I wonder if some people will change their minds about this being bad value
I write the weightweenies blog, hope you like it :)
Disclosure: I'm sponsored by Velocite, but I do give my honest opinion about them (I'm endorsed to race their bikes, not say nice things about them)
dereksmalls
by dereksmalls
That's not too bad a penalty you know over SR for the lower price. I'm still going to wait a couple of years though before heading down that way, also as there is no external wiring kit yet.
roadhog44
by roadhog44
This introduction of Athena has started to make EPS look fairly desirable for me. I've now seen both SuperRecord and this week, Athena EPS - and they feel remarkably similar in use.
The lever shifting feel is really, really nice!
The weight penalty is far less than what I was expecting too :shock:
HammerTime2
by HammerTime2
Tumppi wrote:EPS Athena is about 76g heavier than super record EPS
roadhog44 wrote:The weight penalty is far less than what I was expecting too :shock:
Keep in mind that this weight difference is just for the "electronic" components. The weight differential of the full gruppos is considerably larger.
MajorMantra
by MajorMantra
The Power Torque crank/BB is still a horrible design though...
istigatrice
by istigatrice
HammerTime2 wrote: The weight differential of the full gruppos is considerably larger.
Would it be worth going Athena for the electronic bits and SR for the rest? Then you'll only have a 76g penalty over SR EPS, and you ditch the power torque BB
sugarkane
by sugarkane
Hmm
I got m3 cranks and EE brakes...
As an upgrade kit this looks inviting..
Now how was that thread about cutting the battery open going?
serbelo
by serbelo
Has anyone tried switching the mechanical Chorus carbon levers with the Athena eps alumium levers :idea: ?Do you think they are compatible?Also is it ok to change the RD back plate with fiberlyte ?
Cervelo R2.5
Cervelo P2c
Cervelo R3
Parlee Z3
Parlee TT
Pharmstrong
by Pharmstrong
serbelo wrote:Has anyone tried switching the mechanical Chorus carbon levers with the Athena eps alumium levers :idea: ?Do you think they are compatible?
The Campag EPS maintenance document says "Lever 1 can be replaced as with the mechanical systems".
http://www.campagnolo.com/repository/do ... _07_12.pdf"
There's not enough detail in the exploded drawings to tell if the backside of the mechanical and electronic levers are moulded differently. At any rate, it would appear the carbon Record EPS levers can be used.
http://www.campagnolo.com/repository/do ... -11-12.pdf"
ultyguy
by ultyguy
Bumping this old puppy up....
I was thinking of putting Athena EPS on my Felt AR1. The idea is that I want to be able to swap between a road set up and a full TT set up w/out much recabling and hassle. How easy is this w/ EPS set ups?
fishyskawa
by fishyskawa
I think you should just have to swap the Ergopower's for the EPS bar-ends. The only re-cabling should be between the interface and the shifters. IE: unplug the Ergopower and connect the bar ends.. It may require marginally more work if you also want to use the EPS bar-end brake levers. Anyone else?
natiedean24
by natiedean24
It seems the brake cabling would remain the biggest hassle.
