80mm stem and bars
gherkin
by gherkin
Hi guys
Quick question really. I had a bike fit done at the weekend and it was recommended that I get a 80mm stem and some compact bars. However as I've never changed them on my Kuota since day one I have no idea on what to get.
The bike is Kuota kharma as is mainly used for trialon so has clip tri bars, any idea would be greatly appreciated. I had been looking at 3T ARX Team as the colours would go well with the bike if that's any help
Kjetil
by Kjetil
Deda has short stems and their RHM bar shape is of the short and shallow (compact) variety.
Also check out Zipp.
Bianchi-Campagnolo
NGMN
by NGMN
what rise on the stem?
what shape of bars do you like?
whats your budget for both?
3T stuff is nice. I really like Pro bike components.
simonanks69
by simonanks69
+1 for 3TTT
CARPE DIEM
Colnago C59 Italia GLBK
Up coming custom steel cyclocross :D
Tillquist
by Tillquist
simonanks69 wrote:+1 for 3TTT
+1
See all my bike h e r e
Camilo
by Camilo
Was your fit done on the aero bars?
J.v.S.
by J.v.S.
PRO (Vibe e.g.) has also got decent stems in this length and they usually go well with the Kuota design.
gabriel959
by gabriel959
80mm is quite short, wouldn't that impair the handling of the bike?
gherkin
by gherkin
gabriel959 wrote:80mm is quite short, wouldn't that impair the handling of the bike?
Not sure to be honest haven't ridden it yet since. I imagine it would do but for good or worse I don't know.
Camilo wrote:Was your fit done on the aero bars?
Yes it was
NGMN wrote:what rise on the stem?
Rise on the stem I think is +-6 degrees.
Shape of the bars, I was after a compact set and mainly riding on the hoods I've not really paid much attention to the shape of bars to be honest.
Budget wise, no more that £200
Again guys thanks very much, giving me some idea to look at is great :D
addictR1
by addictR1
wow.. glad to find this thread. today i went out to take my first test ride with my addictR1. the stem i have is the uno 90mm, which i found to be reaching for me. my whole body seem to be forward so when i pedal down, my knee are actually in front of the crank by a bit.
so thinking about getting this Uno 80mm stem: http://tinyurl.com/7hmon3u
the 90mm build and quality and lightweight is spot on. it's + 7 degree.
but would like to hear if it will impair steering or something; which i don't think is should.. would it?
Valbrona
by Valbrona
Getting good position outweighs considerations of handling ... for me and the type of riding I do.
I use an 80mm Deda Zero100 stem and Zero100 bars.
roshea
by roshea
addictR1 wrote:wow.. glad to find this thread. today i went out to take my first test ride with my addictR1. the stem i have is the uno 90mm, which i found to be reaching for me. my whole body seem to be forward so when i pedal down, my knee are actually in front of the crank by a bit.
If you haven't already had a proper fitting, it would be better to get your saddle position looked at FIRST, then adjust reach via changing the stem.
addictR1
by addictR1
my saddle position is locked in and its comfortable
so that's how I can tell if I'm reaching too forward...hope that make sense
darkblue08
by darkblue08
I use a Bontrager triple X 80mm, but if I should go with anything else it would be Zipp Service Course SL stem. I use a Zipp SLC2 bar that support clip-on. When I sprint it shout "Is that all?". The bar has a very narrow tube, compared to my old Ritchey.
To me, position is everything, when you ride 4 hours you need to be comfortable. Its no good riding the last 2 hours with back pains. I bought a couple of cheap stems to try different positions for several rides. That helped me dial into the right position. Now I know for sure that a 70mm is to short and 90mm is to long for me. It cost, but less then a bikefit would, and I could try it for longer periods of time then just a 1-2 hour session on a trainer. It took about a week of cycling before I found that 90mm stem was to long for me.
To have comfort and trust in your position on the bike is priceless!
yeagermeister
by yeagermeister
3T is good stuff, they make your stem angle and there erganova bars have a really good shape to accommodate changes in reach.
