Open mold wide profile carbon wheels
MAJ
by MAJ
And what about internal/external nipples? What do you think is better?
Or holes/no holes for nipples on the rim bed? I think with holes is easier to do maintenance.
Anyone have experience with kapton tape for road wheels, I use this kind of lightweight tape on my MTB rims, but the pressure is 2 bar max not 7bar like in road rims.
kyleFu
by kyleFu
MAJ wrote:
Tue Apr 02, 2019 11:27 am
kyleFu wrote:Farsports new Road disc brake rims / wheels.
40mm deep * 30mm wide rim, 410g / pc +/-15, Hookless + Tubeless.
30mm deep * 28mm wide rim, 390g / pc +/-15g, Tubeless.
35mm deep * 28mm wide rim, 410g / pc +/-15g, Tubeless.
45mm deep * 28mm wide rim, 440g / pc +/-15g, Tubeless.
58mm deep * 28mm wide rim, 460g / pc +/-15g, Tubeless.
35mm deep * 26mm wide rim, 400g / pc +/-15g, Tubeless.
45mm deep * 26mm wide rim, 430g / pc +/-15g, Tubeless.
Wider profile + Ultralight
Interesting rims with good weight.
First option hookless is ok for road or for CX.
I'm searching for light rims.
Where can I find sets with these rims??
A good light option could be:
What do you recommend me?
Rims can be found on Farsports web shop "wheelsfar", in rim section.
Three weights are changed.
45*26 is now 440g/pc+/-15g.
45*28, 450g/pc+/-15g.
58*28, 500g/pc+/-15g.
Farsports
https://www.wheelsfar.com
kyle(at)farsports.cn
kyleFu
by kyleFu
ooo wrote:
Tue Apr 02, 2019 2:00 pm
These are still heavy comparing to clones of enve hookless rims:
28x28mm hookless 305g
30x30mm hookless 315g
Image Image
Farsports has also ultralight XC rims, with impressive weights.
Hookless and Tubeless.
Deep x Wide
25 x 27, 280g/pc+/-15g.
22 x 28, 300g/pc+/-15g.
22 x 30, 310g/pc+/-15g.
30 x 34, 350g/pc+/-15g.
Farsports
ooo
by ooo
1:1 height:width rims are deeper (a little bit more aero) and have extra room to get nipples inside for setup "without holes"
actual weight for asymmetric 28x28 tapeless 24H with glossy finish: 325g
Pinguin
by Pinguin
kyleFu wrote:
Sat Apr 06, 2019 5:52 am
On the 26mm wide Rim,is the 26 on Brake Track or in the middle of the Rim
Cant found pictures of those
Pinguin
by Pinguin
Is it worth to go with asymmetric Rims
Want to buy 45 mm deep rims but only abailable in 40 and 50 rear
TonyM
by TonyM
What does "offset" mean?
Bondurant
by Bondurant
In what context? I couldn't see any recent posts that mentioned the word...
MattMay
by MattMay
Think he’s referring to asymmetric rims.
Bondurant
by Bondurant
In that case...
It means when the rear rim is biased more to the non-drive side in order to get a better bracing angle for the spokes going to the drive side. So if you look at the rim from behind the bike, the bit of the rim where the spokes go in is offset a little to the left.
TonyM
by TonyM
Bondurant wrote:In what context? I couldn't see any recent posts that mentioned the word...
It is sometimes mentioned for the Farsport wheels
MattMay
by MattMay
In this pic of an asymmetric rim you can see the 2.00 offset.
TonyM
by TonyM
Are “regular” wheels (from brands like DT Swiss, campy, Mavic, Enve, etc...);usually with an offset?
Are offset better?
jeanjacques
by jeanjacques
MattMay
by MattMay
Nox Composite rims are asymmetric. And they have scientific details on their site as to why they believe they are better. But as noted above, they are mtb.
