Crown-race reducer?
astranoc
by astranoc
I am looking at replacing my existing fork (1-1/2" to 1-1/8") with an Enve 1.0 fork. Do I need something like that or what exactly?
If an adaptor like this is used, would that affect the handling or anything else? Also would I be able to use a normal campag headset?
BeeBee30
by BeeBee30
I had a similar issue when wanting to fit standard 1 1/8 steerer forks to a Giant Defy frame with an 1 1/4 lower race. I don't think there is anything commercially available, what you show is I think a mountain bike adapter for possibly an external headset? I just basically used a shim to enable me to fit the 1 1/4 inch lower race to a standard 1 1/8 fork crown.
Ti or dye!
BeeBee30
by BeeBee30
Not if you have an internal headset.
Ti or dye!
strobbekoen
by strobbekoen
Chris King headset conversion kit ?
fdegrove
Tubbie Guru
by fdegrove
Hi,
Assuming the 1" Enve fork is a straight piped fork you'll need two different adapters; one to take the 1/2" slack and one for the 1/8" slack.
I'm not sure those even exist.
Any particular reason for this surgery? (Just curious)
Ciao, ;)
thisisatest
by thisisatest
enve 1.0 is a 1-1/8" fork.
i'd go with a crown race, probably by cane creek, that fits a 1-1/8" steerer onto their 1.5" headset bearings. it appears this is what you need: 30mm crown race I.D. with a 52mm O.D.
http://store.canecreek.com/products/productdetail/40-CrownRace-52/30-Steel/part_number=BAA0009S/1739.0.1.1.18069.496.98255.1241.0?pp=8&
astranoc
by astranoc
fdegrove wrote:Any particular reason for this surgery? (Just curious)
Weight loss and hope for better handling!
@thisisatest thanks for that. If I use that crown race do I need a headset like that http://chrisking.com/headsets/hds_onepointfive or my existing 1.5"-1.125" will do? It's 1 1/8" - 1 1/2" Hidden 45x45. Sorry I am very uneducated when it comes down to headset sizes/forks etc..
brearley
by brearley
is there anything to convert a 1 1/8th fork to fit my giant omnium with 1.25 lower bearing race, there are a couple of things from fsa and others for 1.5 lowers but nothing for 1.25?
morxy
by morxy
brearley - did you find anything?
I have the same issue. The head tube of my Giant TCX 2 has a 1 1/8 inch upper diameter and a 1 1/4 lower diameter. I want to use an Easton EC90X fork which has a straight 1 1/8 inch steerer diameter.
Surely there's some kind of adapter for the lower assembly - a lower bearing cup and crown race that swallows the fork's 1 1/8 steerer yet sits in a 1 1/4 head tube?
morxy
by morxy
BeeBee30 wrote:I just basically used a shim to enable me to fit the 1 1/4 inch lower race to a standard 1 1/8 fork crown.
Can I buy this shim anywhere? And it works well for you?
brearley
by brearley
Nope never did find a solution not that I looked too hard. Simplest way would be to find some tubing of 1.25 inch outer diameter with 1.125 internal diameter then use the 1.25 crown race. Not looked at the tcx forks but the omnium has the crown race built in if this is the case on yours you'd have to find someone with a lathe and some engineering skills
brearley
by brearley
